01-08-2016 12:46 AM - edited 07-05-2021 04:28 AM
Hi All,
When AP 1850 becomes the controller, is it able to manage outdoor AP 1570?
From the link below, there is a list of APs supported as Subordinates, does it mean the AP model which is not in the table (such as AP 1570) cannot be managed by the controller AP1850?
(http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn81mr2.html#pgfId-1334201)
Thanks!
01-09-2016 02:50 AM
That is correct. The ME does not support the 1570's at the moment and don't think it will be supported later, but you never know. Here is a link to the matrix also with the supported AP's
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-211427
-Scott
02-27-2018 10:10 PM
Mobility Express solution consists of the following components:
Master Access Point–Cisco Aironet® Access Point 1800, 2800, 3800 series running the virtual Wireless LAN Controller function
Subordinate Access Points–Cisco Aironet® Access Points which are managed by Master Access Point similar to how a Wireless LAN Controller manages Access Points
Cisco Aironet® Access Points which support the Wireless LAN Controller function and operate as Master Access points are listed in the table below:
Table 1 Cisco Aironet® Access Points capable of operating as Master Access Points
Master Access Points Supported Model Numbers
Cisco Aironet® 1830 Series
AIR-AP1832I-x-K9C
Cisco Aironet® 1850 Series
AIR-AP1852I-x-K9C
AIR-AP1852E-x-K9C
Cisco Aironet® 2800 Series
AIR-AP2802I-x-K9C
AIR-AP2802E-x-K9C
Cisco Aironet® 3800 Series
AIR-AP3802I-x-K9C
AIR-AP3802E-x-K9C
Cisco Aironet® Access Points which operate as Subordinate Access Points are listed in the table below.
Cisco Aironet® 700i Series AIR-CAP702I-x-K9
Cisco Aironet® 700w Series AIR-CAP702W-x-K9
Cisco Aironet® 1600 Series
AIR-CAP1602I-x-K9
AIR-CAP1602E-x-K9
Cisco Aironet® 1700 Series AIR-CAP1702I-x-K9
Cisco Aironet® 1810 Series AIR-AP1810W-x-K9
AIR-AP1832I-x-K9C
AIR-AP1852I-x-K9C
AIR-AP1852E-x-K9C
Cisco Aironet® 2600 Series
AIR-CAP2602I-x-K9
AIR-CAP2602E-x-K9
Cisco Aironet® 2700 Series
AIR-CAP2702I-x-K9
AIR-CAP2702E-x-K9
AIR-AP2802I-x-K9C
AIR-AP2802E-x-K9C
Cisco Aironet® 3600 Series
AIR-CAP3602I-x-K9
AIR-CAP3602E-x-K9
Cisco Aironet® 3700 Series
AIR-CAP3702I-x-K9
AIR-CAP3702E-x-K9
AIR-AP3802I-x-K9C
AIR-AP3802E-x-K9
