cisco MSE starting up problem
Mohamed Sayed
hi all
I installed MSE virtual appliance 7.4.100 and cannot add it on the PI 2.0
I tried to reboot the MSE i found this log
starting ipmi drivers: ipmi_si: unable to find any system interface(s)
        [failed]
please advice
kindly find attached photo
Derek Juergens
Were you able to find a solution to this?
Juan Camilo Bayona Ruiz
same problem here.
IPMI is Intel Power Management Interface. You only have this on Intel servers, not in a virtual environment. Also this shouldn't cause the server to not work.
@Juan Camilo Bayona Ruiz Which version did you try to install? Virtual or physical?
Yes, the MSE is working fine. I though it was the cause of the issue but it was not. Thanks
