Cisco Virtual Wireless Controller - DTLS Supported??
michaelgitonga
Does the Cisco Virtual Wireless Controller support DTLS??
Freerk Terpstra
Level 7
Level 7
If you mean the secure capwap connection than yes, but it depends on your country if you are allowed to use it. This is no other than with the physical WLC.
There is an bug related to adding the DTLS license in the vWLC: CSCut39974.
The Cisco Virtual Wireless Controller Data Sheet indicate that DTLS is supported while the Q&A indicates it is NOT. By the way why do we need DTLS??
(http://www.cisco.com/c/en/us/products/collateral/wireless/virtual-wireless-controller/data_sheet_c78-714543.html)
http://www.cisco.com/c/en/us/products/collateral/wireless/virtual-wireless-controller/qa_c67-715130.html
The following table summarizes the feature differences between 7500 and Virtual controller:
