Cisco vWLC - AP's not broadcasting SSID's
deyster94
Level 5
Level 5
I am running the demo of the virtual WLC and have one 1142N AP connected to it.  I have two WLAN's created and they are configured to broadcast their SSID's.  However, when I look on my laptop or Android, I cannot see either of them.  I checked the AP to see if it has the WLAN's on it and it does.  I did this by going to Wireless -> Access Points -> Radios -> 802.11a/n AP Interfaces -> Details.  Under Station Configuration Parameters -> Number of WLAN's, there are 2, which is correct.
I had this demo running on VMware workstation and had some bridging issues with it and thought that was the issue.  I now have it running on ESX5.1 and am still having this issue.  I am at a loss as to what is causing this problem.
One other note, the AP is receiving power through a power injector.  Not sure if that makes a difference or not.
TIA for any help.
Dan
5 Replies 5
Stephen Rodriguez
what are the WLAN ID's for them?  If you created them as => 17, you need to create an AP group
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
I actually figured it out.  I needed to put the AP in flexconnect mode and not local.  Would be nice if they removed the local option and made flexconnect the default setting.
Thanks for the information, I was the same problem and I solved the problem by changing access point to Flexconnect mode.
Thank you, i solved too with this change.
