Cisco Wireless AP's POE
JAYESH RAMAIYA
We need to install some wireless AP's and will not be installed on a POE switch. We have purchased the invertors and I believe that I need to add a line into the config.
Is the line below correct to enter into the config if you have an AP using a POE  invertor?
power inline negotiation prestandard source
Thank you
Scott Fella
That is correct for autonomous APs.
-Scott
OK
So when is this used for?
power inline negotiation injector override
power inline negotiation injector override is the command to use if you have a power injector.  The other one is for a POE switch that doesn't support 802.3af power.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
