10-30-2018 01:44 PM - edited 07-05-2021 09:23 AM
Cisco Wireless LAN Controllers in SSO are not broadcasting a SSID consistently some access points are broadcasting the USSID however others appear to not be broadcasting the SSID despite being in the same AP group this is causing the connectivity to this SSID to be patchy and dropouts are occurring when roaming.
10-30-2018 02:24 PM
10-30-2018 02:30 PM - edited 10-30-2018 02:37 PM
Yes some AP's are not broadcasting the SSID
10-30-2018 02:43 PM
10-31-2018 11:07 AM
How does one check which AP is not broadcasting the SSID as there is over 20 APs in the environment
10-31-2018 02:50 PM
We use a tool called "Mark 1 Eyeball". If you are THE (wireless) network engineer you need to be there to verify what the complaints are.
11-01-2018 05:04 PM
