At one of my customer we have installed Cisco wlc 2504 and has been integrated with AD for authenticating the users. The windows server version is 2003. Now the wifi user is getting authenticated and is able to connect to the domain but the issue is that the group policies are not being pushed to the wifi users. If the same user connects through the wired network, the group policies are being pushed.
check this link
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a008093f1b9.shtml
Jawad
Hi jawad,
First of all thanks for replying, but the issue still remains. The wireless users are authenticated by AD but the GPO is not pushed to them. When the same user connects through the wired network all the GPO is pushed.
What is the authentication mechanism you use? I am guessing its user-based PEAP.
What happens if after user successfully authenticates and gets authorized to WLAN - can he/she run the gpoupdate and get the policies?
You're want to take a look into machine authentication
Steve
Kindly follow the following link for the Group policy, complete step by step configuration
Server 2008/2012
cisco document (another explaining in detail the flow)
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080921f67.shtml
Please try the steps which is provided in the link. The link is on 2008 server setting but you can just verify the settings missing in you configuration for refrence.
The issue with user auth is that it does not online before the user logs in. GPOs are normally applied at boot. Since the user is not logged in during the bootup the computer is unable to download the GPO.
The workaround for this is to do "Computer + User" for authentication. the Computer's machine account to log in and download the GPO via wireless and the. Switch to the user account when the user logs in.
Note that the machine behavior changes from WinXP to Vista/7/8
