Cisco WLC Read Only acess in ACS
Saurabh.s
Hi ALl,
I am working to setup read only access to Cisco wireless controller through TACACS.
I have setup a shell profile with attributes as role1:MONITOR, role1:WLANs, to provide access to user to thses 2 only.
Nothing mentioned in command set, But still user is getting full access.
Can anyone guide what I am missing here.
While trying below is the logs coming on wlC:
%EMWEB-3-LOGIN_FAILED: [PA]ews_auth.c:2281 Login failed for the user:abc. Service-Type is not present or it doesn't allow READ/WRITE permission..
Its bit urgent, need resolution quickly pls.
luis_cordova
Hi @Saurabh.s ,
I tell you that there is an event in the community in Spanish about WLC:
https://community.cisco.com/t5/eventos-wireless-mobility/pregunte-al-experto-evento-mejores-pr%C3%A1cticas-y-tips-para/ba-p/3848125
I know that the expert could help you in English, if you need it.
