09-01-2022 04:19 AM
I have WLC3504 and Aironet APS. I would like to buy catalyst APs and connect to WLC. Does anybody have that experience, and how goes license for that model?
Thank you very much.
Solved! Go to Solution.
09-01-2022 04:50 AM - edited 09-01-2022 04:53 AM
- They will use the existing available licenses on the 3504 , but you need to look into : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html and check aireos software requirements (versions) for the catalysts AP and or if the particular model can run under 3504/Aireos-version-in-place at all. Have a look at Table 7.
M.
M.
09-01-2022 04:58 AM
