CLI commande for SSID mapping to tunnel
nt0000001
Level 2
Level 2
What would be the commande to map an SSID ti a mobility tunnel ?
In WEB mode (in attachement) we have :
WLAN > WLAN index (conf) Mobility Anchors and here i have "Mobility Anchor Create" and i put the IP of other WLC.
On the Anchor WLC a create an mobility anchor "Local".
How can i do this in CLI ?
Thx
Rasika Nayanajith
As long as you configure mobility peering between those two WLC, you can configure a WLAN via CLI to anchor as shown below
(WLC) >config wlan mobility ?
anchor Configures the Mobility WLAN anchor list.
foreign-map Configures the Mobility WLAN foreign-map.
(WLC) >config wlan mobility anchor ?
add Add/Change a Mobility anchor to a WLAN.
delete Delete a Mobility anchor from a WLAN.
(WLC) >config wlan mobility anchor add ?
<WLAN Id> WLAN identifier between 1 and 512.
(WLC) >config wlan mobility anchor add 100 ?
<IP addr> Member switch IP address to anchor WLAN
Here is reference to mobility peering config
https://mrncciew.com/2013/05/20/mobility-config-via-cli/
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
But what about "local" mapping ?
as i said the WLC1 will "tunnel" de traffic to WLC2. WLC2 will "keep" traffic as local (Create mobility anchor > local)
Should i put his own IP in CLI ?
But what about "local" mapping ? Should i put his own IP in CLI ?
Yes, you use same command syntax. You will use same controller mgmt IP address if that is anchor WLC.
Rasika
OK Thank you so much.
This subject is closed for me
PS: i'm very often on your web to find some responses
