Client get wrong IP address on Air 1700 and WLC2504
teera2526
I have experienced that client get wrong ip when connect to wireless
i have 2 wireless profile 1. internal wlan and guest when client connect to guest they get correct ip but when connect to internal wlan client also get "guest" IP
so i have attached my configuration
5 Replies 5
Leo Laohoo
Check the DHCP IP address of the Dynamic Interface settings for the internal WLAN SSID.
did u mean i have to create dhcp int for internal wlan and guest right?
If you're following the "traditional" method of each SSID is assigned to a specific Dynamic Interface, then yes, each check each of the Dynamic Interface settings and look at the DHCP settings.  Make sure there is a DHCP scope for the two different subnets.
I have attach my scenario setup. The problem is when i move dhcp ip to dhcp server.
on my lab test i have created dhcp on core sw, never problem.
