Client Roaming between AP - WLC 5508
AlexKlmv
Hello everybody!
Wlc 5508 controller
There is such a problem:
A client stuck to a point with a good signal, after turning off this AP, moves to another AP with a worse signal.
But after turning on the first point, the client for some reason does not return back, he sticks to the point with the worst signal.
Advise what could be the problem
What settings should I see?
Optimized roaming is enable
balaji.bandi
I do not believe that the Client can go back as you expecting until the client moves out of reach to the AP that was connected, the client always connects to the AP it was connected, the client decides what AP to connect.
even i saw practically, the one top of my head my device can not connect, it connects far from other AP.
BB
balaji.bandi
BB
...just thought where the signal is better, then the client connects there
Nevertherless thank you.
Rich R
Some WiFi drivers (like Intel) have a "Roaming Aggresiveness" setting.  If you set that to Highest the client will move APs more readily but it's still down to the client to decide when the roaming threshold has been reached.  All that setting does is change the threshold to make it more or less sensitive = roam quickly or cling to the AP as long as possible.  Use with caution and test thoroughly because most users will just leave it at the default Medium.
https://www.intel.co.uk/content/www/uk/en/support/articles/000005546/wireless/legacy-intel-wireless-products.html
Availability of that setting depends on WiFi adapter model and driver version.
