Clients unable to connect to Wifi at remote location
classicstripes
Hi all,
While trying to connect to WiFi at remote sites APs, the connection is getting time out.
User are getting error as 'Unable to connect to <WiFi-SSID>'
The APs at corporate office are functioning properly and user are able to connect to the APs.
Wifi Controller: 2504 Software ver: 7.3.101.0
Authentication 802.1x
Please assist in resolving the same.
Scott Fella
So I see you have 3 SSID's and two of them are using radius authentication. If you look at the configuration between the two radius configured SSID's you will notice the one that works is using WPA2/AES and the one that doesn't (CSPL_Wifi) is using WPA2/TKIP & AES. This is or might be your issue. You need to disable TKIP and just use WPA2/AES.
When using WPA you use TKIP, when using WPA2, you use AES.
Try this and let us know.
-Scott
7 Replies 7
Scott Fella
You need to provide us more info.  Are you using FlexConnect or all the AP's local.  Can you post your show run-config and tell us what ssid you are having issues with.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Hi Scott,
The APs are in FlexConnect mode at remote sites. The config of the WLC is as stated below
Issue is with CSPL_Wifi SSID
(Cisco Controller) >show run-config
Press Enter to continue...
System Inventory
NAME: "Chassis"    , DESCR: "Cisco 2500 Series Wireless LAN Controller"
PID: AIR-CT2504-K9,  VID: V01,  SN: PSZ164206NK
Burned-in MAC Address............................ 6C:20:56:B8:96:60
Maximum number of APs supported.................. 15
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.3.101.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... CLASSICWLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... xxx.xxx.xxx.xxx
Last Reset....................................... Power on reset
System Up Time................................... 27 days 19 hrs 45 mins 6 secs
System Timezone Location.........................
Configured Country............................... IN  - India
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +20 C
External Temperature............................. +25 C
Fan Status....................................... 4300 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 42
AP Bundle Information
Primary AP Image    Size
ap1g2            10596
ap3g1            11088
ap3g2            10968
ap801            7092
ap802            8428
c1130            5072
c1140            9288
c1250            6784
c1520            7852
c602i            3736
Secondary AP Image    Size
ap3g1            5792
ap801            5192
ap802            5232
c1100            3084
c1130            4964
c1140            4992
c1200            3364
c1240            4812
c1250            5504
c1310            3136
c1520            6404
c3201            4324
c602i            3716
Switch Configuration
802.3x Flow Control Mode......................... Disable
FIPS prerequisite features....................... Disabled
secret obfuscation............................... Enabled
Strong Password Check Features:
     case-check ...........Enabled
     consecutive-check ....Enabled
     default-check .......Enabled
     username-check ......Enabled
Network Information
RF-Network Name............................. CLASSIC
Web Mode.................................... Enable
Secure Web Mode............................. Disable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Disable
Secure Web Mode RC4 Cipher Preference....... Disable
OCSP........................................ Disabled
OCSP responder URL..........................
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Multicast   Address : 0.0.0.0
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
IGMP Query Interval......................... 20 seconds
MLD snooping................................ Disabled
MLD timeout................................. 60 seconds
MLD query interval.......................... 20 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Enabled
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Enable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
AP Fallback ................................ Enable
Web Auth Redirect Ports .................... 80
Web Auth Proxy Redirect  ................... Disable
Web Auth Captive-Bypass   .................. Disable
Web Auth Secure Web  ....................... Enable
Fast SSID Change ........................... Enabled
AP Discovery - NAT IP Only ................. Disabled
IP/MAC Addr Binding Check .................. Enabled
CCX-lite status ............................ Disable
oeap-600 dual-rlan-ports ................... Disable
oeap-600 local-network ..................... Enable
Port Summary
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE
1  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A
2  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
3  Normal  Disa Enable  Auto       Auto       Down   Enable  Enable  (Power Off)
4  Normal  Disa Enable  Auto       Auto       Down   Enable  Enable  (Power Off)
AP Summary
Number of APs.................................... 10
Global AP User Name.............................. Not Configured
Global AP Dot1x User Name........................ Not Configured
AP Name             Slots  AP Model              Ethernet MAC       Location          Port  Country  Priority
HO_3rd_Floor         2     AIR-CAP2602I-N-K9     fc:99:47:d9:a9:a6      Astarc House  1        IN       1
HO_4th_Floor         2     AIR-CAP2602I-N-K9     00:3a:9a:ab:b9:b5      Astarc House  1        IN       1
HO_6th_Floor         2     AIR-CAP2602I-N-K9     fc:99:47:d9:a9:99      Astarc House  1        IN       1
HO_5th_Floor         2     AIR-CAP2602I-N-K9     00:3a:9a:ab:b9:82      Astarc House  1        IN       1
HO_2nd_Floor         2     AIR-CAP2602I-N-K9     fc:99:47:d9:a9:86      Astarc House  1        IN       1
APECC8.82BA.C418     2     AIR-OEAP602I-A-K9     ec:c8:82:ba:c4:18      IndonesiaAP1  1        IN       1
Unit1                2     AIR-CAP2602I-N-K9     00:3a:9a:ab:b2:c0             Unit1  1        IN       1
Pelhar_IT            2     AIR-CAP2602I-N-K9     00:3a:9a:ab:b9:7e            Pelhar  1        IN       1
Pelhar_Rcptn         2     AIR-CAP2602I-N-K9     00:3a:9a:ab:b9:89            Pelhar  1        IN       1
Pelhar_Admin         2     AIR-CAP2602I-N-K9     fc:99:47:d9:a9:9d            Pelhar  1        IN       1
AP Tcp-Mss-Adjust Info
AP Name              TCP State  MSS Size
HO_3rd_Floor         disabled   -
HO_4th_Floor         disabled   -
HO_6th_Floor         disabled   -
HO_5th_Floor         disabled   -
HO_2nd_Floor         disabled   -
APECC8.82BA.C418     disabled   -
Unit1                disabled   -
Pelhar_IT            disabled   -
Pelhar_Rcptn         disabled   -
Pelhar_Admin         disabled   -
AP Location
Total Number of AP Groups........................ 0
Site Name........................................ default-group
Site Description.................................
AP Operating Class............................... Not-configured
RF Profile
2.4 GHz band.....................................
5 GHz band.......................................
WLAN ID          Interface          Network Admission Control          Radio Policy
1               management           Disabled                          None
2               management           Disabled                          None
3               management           Disabled                          None
RF Profile
Number of RF Profiles............................ 0
Out Of Box State................................. Disabled
RF Profile Name            Band     Description                 Applied
AP Config
Cisco AP Identifier.............................. 17
Cisco AP Name.................................... HO_3rd_Floor
Country code..................................... IN  - India
Regulatory Domain allowed by Country............. 802.11bg:-A     802.11a:-DN
AP Country code.................................. IN  - India
AP Regulatory Domain............................. -A
Switch Port Number .............................. 1
MAC Address...................................... fc:99:47:d9:a9:a6
IP Address Configuration......................... DHCP
IP Address....................................... xxx.xxx2.225
IP NetMask....................................... 255.255.254.0
Gateway IP Addr.................................. xxx.xxx2.1
NAT External IP Address.......................... None
CAPWAP Path MTU.................................. 1485
Telnet State..................................... Enabled
Ssh State........................................ Disabled
Cisco AP Location................................ Astarc House
Cisco AP Group Name.............................. default-group
Primary Cisco Switch Name........................
Primary Cisco Switch IP Address.................. Not Configured
Secondary Cisco Switch Name......................
Secondary Cisco Switch IP Address................ Not Configured
Tertiary Cisco Switch Name.......................
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... Local
Public Safety ................................... Disabled
AP SubMode ...................................... Not Configured
Remote AP Debug ................................. Disabled
Logging trap severity level ..................... informational
Logging syslog facility ......................... kern
S/W  Version .................................... 7.3.101.0
Boot  Version ................................... 12.4.25.1
Mini IOS Version ................................ 7.3.1.73
Stats Reporting Period .......................... 180
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Disabled
PoE Power Injector MAC Addr...................... Disabled
Power Type/Mode.................................. Power injector / Normal mode
Number Of Slots.................................. 2
AP Model......................................... AIR-CAP2602I-N-K9
AP Image......................................... C2600-K9W8-M
IOS Version...................................... 15.2(2)JA$
Reset Button..................................... Enabled
AP Serial Number................................. FGL1648Z2VL
AP Certificate Type.............................. Manufacture Installed
AP User Mode..................................... CUSTOMIZED
AP User Name..................................... admin
AP Dot1x User Mode............................... Not Configured
AP Dot1x User Name............................... Not Configured
Cisco AP system logging host..................... 255.255.255.255
AP Up Time....................................... 10 days, 17 h 21 m 40 s
AP LWAPP Up Time................................. 8 days, 13 h 36 m 34 s
Join Date and Time............................... Wed May 22 20:23:05 2013
Join Taken Time.................................. 0 days, 00 h 07 m 46 s
Attributes for Slot  0
    Radio Type................................... RADIO_TYPE_80211n-2.4
    Administrative State ........................ ADMIN_ENABLED
    Operation State ............................. UP
    Radio Role .................................. ACCESS
    CellId ...................................... 0
    Station Configuration
      Configuration ............................. AUTOMATIC
      Number Of WLANs ........................... 3
      Medium Occupancy Limit .................... 100
      CFP Period ................................ 4
      CFP MaxDuration ........................... 60
      BSSID ..................................... 84:78:ac:b8:34:d0
      Operation Rate Set
        1000 Kilo Bits........................... MANDATORY
        2000 Kilo Bits........................... MANDATORY
        5500 Kilo Bits........................... MANDATORY
        11000 Kilo Bits.......................... MANDATORY
        6000 Kilo Bits........................... SUPPORTED
        9000 Kilo Bits........................... SUPPORTED
        12000 Kilo Bits.......................... SUPPORTED
        18000 Kilo Bits.......................... SUPPORTED
        24000 Kilo Bits.......................... SUPPORTED
        36000 Kilo Bits.......................... SUPPORTED
        48000 Kilo Bits.......................... SUPPORTED
        54000 Kilo Bits.......................... SUPPORTED
      MCS Set
        MCS 0.................................... SUPPORTED
        MCS 1.................................... SUPPORTED
        MCS 2.................................... SUPPORTED
        MCS 3.................................... SUPPORTED
        MCS 4.................................... SUPPORTED
        MCS 5.................................... SUPPORTED
        MCS 6.................................... SUPPORTED
        MCS 7.................................... SUPPORTED
        MCS 8.................................... SUPPORTED
        MCS 9.................................... SUPPORTED
        MCS 10................................... SUPPORTED
        MCS 11................................... SUPPORTED
        MCS 12................................... SUPPORTED
        MCS 13................................... SUPPORTED
        MCS 14................................... SUPPORTED
        MCS 15................................... SUPPORTED
        MCS 16................................... SUPPORTED
        MCS 17................................... SUPPORTED
        MCS 18................................... SUPPORTED
        MCS 19................................... SUPPORTED
        MCS 20................................... SUPPORTED
        MCS 21................................... SUPPORTED
        MCS 22................................... SUPPORTED
        MCS 23................................... SUPPORTED
      Beacon Period ............................. 100
      Fragmentation Threshold ................... 2346
      Multi Domain Capability Implemented ....... TRUE
      Multi Domain Capability Enabled ........... TRUE
      Country String ............................ IN
      First Chan Num ............................ 1
      Number Of Channels ........................ 11
    MAC Operation Parameters
      Packet Retry Limit ........................ 64
    Tx Power
      Num Of Supported Power Levels ............. 7
      Tx Power Level 1 .......................... 17 dBm
      Tx Power Level 2 .......................... 14 dBm
      Tx Power Level 3 .......................... 11 dBm
      Tx Power Level 4 .......................... 8 dBm
      Tx Power Level 5 .......................... 5 dBm
      Tx Power Level 6 .......................... 2 dBm
      Tx Power Level 7 .......................... -1 dBm
      Tx Power Configuration .................... AUTOMATIC
      Current Tx Power Level .................... 1
    Phy OFDM parameters
      Current Channel ........................... 11
      Extension Channel ......................... NONE
      Channel Width.............................. 20 Mhz
      Allowed Channel List....................... 1,2,3,4,5,6,7,8,9,10,11
      TI Threshold .............................. -50
      Legacy Tx Beamforming Configuration ....... CUSTOMIZED
      Legacy Tx Beamforming ..................... ENABLED
      Antenna Type............................... INTERNAL_ANTENNA
      Internal Antenna Gain (in .5 dBi units).... 8
      Diversity.................................. DIVERSITY_ENABLED
      802.11n Antennas
         A....................................... ENABLED
         B....................................... ENABLED
         C....................................... ENABLED
         D....................................... ENABLED
    Performance Profile Parameters
      Interference threshold..................... 10 %
      Noise threshold............................  -70 dBm
      RF utilization threshold................... 80 %
      Data-rate threshold........................ 1000000 bps
      Client threshold........................... 12 clients
      Coverage SNR threshold..................... 12 dB
      Coverage exception level................... 25 %
      Client minimum exception level............. 3 clients
    Rogue Containment Information
    Containment Count............................ 0
    CleanAir Management Information
        CleanAir Capable......................... Yes
        CleanAir Management Admin State.......... Enabled
        CleanAir Management Operation State...... Down
        Rapid Update Mode........................ Off
        Spectrum Expert connection............... Enabled
          CleanAir NSI Key....................... 325B6F9AD2DB90FCD74700E94CB25C34
          Spectrum Expert Connections counter.... 0
        CleanAir Sensor State.................... Configured
    Radio Extended Configurations
      Beacon period.............................. 100 milliseconds
      Beacon range............................... AUTO
      Multicast buffer........................... AUTO
      Multicast data-rate........................ AUTO
      RX SOP threshold........................... AUTO
      CCA threshold.............................. AUTO
AP Regulatory Domain............................. -N
Attributes for Slot  1
    Radio Type................................... RADIO_TYPE_80211n-5
    Radio Subband................................ RADIO_SUBBAND_ALL
      Operation Rate Set
        6000 Kilo Bits........................... MANDATORY
        12000 Kilo Bits.......................... MANDATORY
        24000 Kilo Bits.......................... MANDATORY
      MCS Set
      First Chan Num ............................ 36
      Number Of Channels ........................ 13
    Tx Power
      Num Of Supported Power Levels ............. 6
      Tx Power Level 1 .......................... 14 dBm
      Tx Power Level 2 .......................... 11 dBm
      Tx Power Level 3 .......................... 8 dBm
      Tx Power Level 4 .......................... 5 dBm
      Tx Power Level 5 .......................... 2 dBm
      Tx Power Level 6 .......................... -1 dBm
    Phy OFDM parameters
      Current Channel ........................... 36
      Allowed Channel List....................... 36,40,44,48,52,56,60,64,149,
        ......................................... 153,157,161,165
      802.11n Antennas
      Coverage SNR threshold..................... 16 dB
Cisco AP Identifier.............................. 26
Cisco AP Name.................................... HO_4th_Floor
MAC Address...................................... 00:3a:9a:ab:b9:b5
IP Address....................................... xxx.xxx2.157
AP Serial Number................................. FGL1648Z2VG
AP Up Time....................................... 25 days, 00 h 07 m 21 s
AP LWAPP Up Time................................. 8 days, 13 h 36 m 32 s
Join Date and Time............................... Wed May 22 20:23:08 2013
Join Taken Time.................................. 0 days, 00 h 07 m 51 s
      BSSID ..................................... 1c:e6:c7:1c:dc:c0
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
          CleanAir NSI Key....................... FC43232E3A1A3B26A5339FA323C0B4A7
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      Current Channel ........................... 149
      802.11n Antennas
Cisco AP Identifier.............................. 21
Cisco AP Name.................................... HO_6th_Floor
MAC Address...................................... fc:99:47:d9:a9:99
IP Address....................................... xxx.xxx2.190
AP Serial Number................................. FGL1648Z2VJ
AP Up Time....................................... 124 days, 13 h 15 m 47 s
Join Date and Time............................... Wed May 22 20:23:09 2013
Join Taken Time.................................. 0 days, 00 h 07 m 37 s
      BSSID ..................................... 84:78:ac:b8:34:00
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
          CleanAir NSI Key....................... 450B724F526D778E33609F4802C3CEAB
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      Current Channel ........................... 44
      802.11n Antennas
Cisco AP Identifier.............................. 27
Cisco AP Name.................................... HO_5th_Floor
MAC Address...................................... 00:3a:9a:ab:b9:82
IP Address....................................... xxx.xxx3.17
AP Serial Number................................. FGL1648Z2VM
AP Up Time....................................... 87 days, 16 h 08 m 42 s
AP LWAPP Up Time................................. 8 days, 13 h 36 m 15 s
Join Date and Time............................... Wed May 22 20:23:27 2013
Join Taken Time.................................. 0 days, 00 h 08 m 11 s
      BSSID ..................................... 1c:e6:c7:1c:d9:90
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
          CleanAir NSI Key....................... 8EB50B5854395046B244B543E1FB7DD7
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      Current Channel ........................... 161
      802.11n Antennas
Cisco AP Identifier.............................. 8
Cisco AP Name.................................... HO_2nd_Floor
MAC Address...................................... fc:99:47:d9:a9:86
IP Address....................................... xxx.xxx2.183
AP Serial Number................................. FGL1648Z2VN
AP Up Time....................................... 14 days, 16 h 49 m 45 s
AP LWAPP Up Time................................. 6 days, 17 h 05 m 37 s
Join Date and Time............................... Fri May 24 16:54:06 2013
Join Taken Time.................................. 0 days, 00 h 04 m 47 s
      BSSID ..................................... 84:78:ac:b8:32:e0
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
          CleanAir NSI Key....................... E073A32361256C8485CC9448183D79C1
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      Current Channel ........................... 48
      802.11n Antennas
Cisco AP Identifier.............................. 41
Cisco AP Name.................................... APECC8.82BA.C418
MAC Address...................................... ec:c8:82:ba:c4:18
IP Address Configuration......................... Static IP assigned
IP Address....................................... Disabled
Telnet State..................................... Disabled
Cisco AP Location................................ IndonesiaAP1
Primary Cisco Switch Name........................ PublicWLC
Primary Cisco Switch IP Address.................. 119.226.7.192
Secondary Cisco Switch Name...................... PrivateWLC
Secondary Cisco Switch IP Address................ xxx.xxx.xxx.xxx
Operation State ................................. UP
Boot  Version ................................... 5.10.144.16
Mini IOS Version ................................ 7.0.112.71
Stats Reporting Period .......................... 0
PoE Pre-Standard Switch.......................... Not applicable
PoE Power Injector MAC Addr...................... Not applicable
AP Model......................................... AIR-OEAP602I-A-K9
IOS Version...................................... 5.22.84.6
Reset Button..................................... Disabled
AP Serial Number................................. FGL1709N00F
AP Up Time....................................... 2 days, 01 h 17 m 39 s
AP LWAPP Up Time................................. 2 days, 01 h 16 m 52 s
Join Date and Time............................... Wed May 29 08:42:52 2013
Join Taken Time.................................. 0 days, 00 h 00 m 46 s
      Configuration ............................. CUSTOMIZED
      Medium Occupancy Limit .................... 0
      CFP Period ................................ 0
      CFP MaxDuration ........................... 0
      BSSID ..................................... 00:3a:9a:e5:c7:20
      Operation Rate Set
      MCS Set
        MCS 16................................... DISABLED
        MCS 17................................... DISABLED
        MCS 18................................... DISABLED
        MCS 19................................... DISABLED
        MCS 20................................... DISABLED
        MCS 21................................... DISABLED
        MCS 22................................... DISABLED
        MCS 23................................... DISABLED
    Tx Power
      Num Of Supported Power Levels ............. 5
      Tx Power Level 1 .......................... 19 dBm
      Tx Power Level 2 .......................... 16 dBm
      Tx Power Level 3 .......................... 13 dBm
      Tx Power Level 4 .......................... 10 dBm
      Tx Power Level 5 .......................... 8 dBm
    Phy OFDM parameters
      Legacy Tx Beamforming Configuration ....... AUTOMATIC
      Legacy Tx Beamforming ..................... DISABLED
      Internal Antenna Gain (in .5 dBi units).... 6
      802.11n Antennas
      Interference threshold..................... 0 %
        CleanAir Capable......................... No
    Regulatory Domain check for this slot has Failed. This slot will not be operational
Cisco AP Name.................................... Unit1
MAC Address...................................... 00:3a:9a:ab:b2:c0
IP Address....................................... xxx.xxx12.129
IP NetMask....................................... 255.255.255.0
Gateway IP Addr.................................. xxx.xxx12.1
Ssh State........................................ Enabled
Cisco AP Location................................ Unit1
AP Mode ......................................... FlexConnect
AP Serial Number................................. FGL1648Z2VZ
FlexConnect Vlan mode :.......................... Disabled
FlexConnect Group................................ Not a member of any group
Group VLAN ACL Mappings
FlexConnect Local-Split ACLs :
WLAN ID   PROFILE NAME                       ACL                                 TYPE
Flexconnect Central-Dhcp Values :
WLAN ID   PROFILE NAME                         Central-Dhcp      DNS Override      Nat-Pat     Type
  1       CSPL_Wifi                                False             False          False      Wlan
  3       CSPL_Wifi_T                              False             False          False      Wlan
FlexConnect Backup Auth Radius Servers :
Static Primary Radius Server.................... Disabled
Static Secondary Radius Server.................. Disabled
Group Primary Radius Server..................... Disabled
Group Secondary Radius Server................... Disabled
AP Up Time....................................... 13 days, 17 h 30 m 06 s
AP LWAPP Up Time................................. 1 days, 06 h 52 m 14 s
Join Date and Time............................... Thu May 30 03:07:31 2013
Join Taken Time.................................. 0 days, 02 h 26 m 48 s
      BSSID ..................................... 1c:e6:c7:1c:6d:50
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
          CleanAir NSI Key....................... A7A3EC22D17AE903E63C67301DB67914
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
Cisco AP Identifier.............................. 48
Cisco AP Name.................................... Pelhar_IT
MAC Address...................................... 00:3a:9a:ab:b9:7e
IP Address....................................... xxx.xxx5.2
Gateway IP Addr.................................. xxx.xxx4.1
NAT External IP Address.......................... 115.254.58.50:6417
Cisco AP Location................................ Pelhar
Primary Cisco Switch Name........................ ClassicWLC
Primary Cisco Switch IP Address.................. xxx.xxx.xxx.xxx
AP Serial Number................................. FGL1648Z2VP
AP Up Time....................................... 2 days, 22 h 56 m 42 s
AP LWAPP Up Time................................. 0 days, 23 h 33 m 56 s
Join Date and Time............................... Thu May 30 10:25:50 2013
Join Taken Time.................................. 0 days, 00 h 12 m 22 s
      BSSID ..................................... 1c:e6:c7:1c:d9:40
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
          CleanAir NSI Key....................... 60996F0178A6D9B2013743B42978E4DC
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
Cisco AP Identifier.............................. 14
Cisco AP Name.................................... Pelhar_Rcptn
MAC Address...................................... 00:3a:9a:ab:b9:89
IP Address....................................... xxx.xxx5.10
NAT External IP Address.......................... 115.254.58.50:45329
AP Serial Number................................. FGL1648Z2VX
AP User Mode..................................... AUTOMATIC
AP User Name..................................... Not Configured
AP Up Time....................................... 0 days, 15 h 10 m 25 s
AP LWAPP Up Time................................. 0 days, 15 h 09 m 05 s
Join Date and Time............................... Thu May 30 18:50:42 2013
Join Taken Time.................................. 0 days, 00 h 01 m 19 s
      BSSID ..................................... 1c:e6:c7:1c:da:00
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
          CleanAir NSI Key....................... E750CDAA72BD5D7A333535C89D4BA3EA
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
Cisco AP Identifier.............................. 15
Cisco AP Name.................................... Pelhar_Admin
MAC Address...................................... fc:99:47:d9:a9:9d
IP Address....................................... xxx.xxx5.7
NAT External IP Address.......................... 115.254.58.50:36882
AP Serial Number................................. FGL1648Z2VQ
AP Up Time....................................... 0 days, 15 h 10 m 26 s
AP LWAPP Up Time................................. 0 days, 15 h 09 m 06 s
      BSSID ..................................... 84:78:ac:b8:34:40
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
          CleanAir NSI Key....................... 1232569DD4804F655EAB792AD12BF3FC
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      Current Channel ........................... 153
      802.11n Antennas
AP Airewave Director Configuration
AP Name.......................................... HO_3rd_Floor
  Slot ID........................................ 0
  Radio Type..................................... RADIO_TYPE_80211b/g
  Sub-band Type.................................. All
  Noise Information
    Noise Profile................................ PASSED
    Channel 1....................................  -95 dBm
    Channel 2....................................  -95 dBm
    Channel 3....................................  -95 dBm
    Channel 4....................................  -95 dBm
    Channel 5....................................  -95 dBm
    Channel 6....................................  -95 dBm
    Channel 7....................................  -94 dBm
    Channel 8....................................  -95 dBm
    Channel 9....................................  -95 dBm
    Channel 10...................................  -95 dBm
    Channel 11...................................  -95 dBm
  Interference Information
    Interference Profile......................... PASSED
    Channel 1.................................... -128 dBm @  0 % busy
    Channel 2.................................... -128 dBm @  0 % busy
    Channel 3.................................... -128 dBm @  0 % busy
    Channel 4.................................... -128 dBm @  0 % busy
    Channel 5.................................... -128 dBm @  0 % busy
    Channel 6.................................... -128 dBm @  0 % busy
    Channel 7.................................... -128 dBm @  0 % busy
    Channel 8.................................... -128 dBm @  0 % busy
    Channel 9.................................... -128 dBm @  0 % busy
    Channel 10................................... -128 dBm @  0 % busy
    Channel 11................................... -128 dBm @  0 % busy
  Load Information
    Load Profile................................. PASSED
    Receive Utilization.......................... 0 %
    Transmit Utilization......................... 8 %
    Channel Utilization.......................... 22 %
    Attached Clients............................. 5 clients
  Coverage Information
    Coverage Profile............................. PASSED
    Failed Clients............................... 0 clients
  Client Signal Strengths
    RSSI -100 dbm................................ 0 clients
    RSSI  -92 dbm................................ 0 clients
    RSSI  -84 dbm................................ 0 clients
    RSSI  -76 dbm................................ 0 clients
    RSSI  -68 dbm................................ 0 clients
    RSSI  -60 dbm................................ 2 clients
    RSSI  -52 dbm................................ 4 clients
  Client Signal To Noise Ratios
    SNR    0 dB.................................. 0 clients
    SNR    5 dB.................................. 0 clients
    SNR   10 dB.................................. 0 clients
    SNR   15 dB.................................. 0 clients
    SNR   20 dB.................................. 0 clients
    SNR   25 dB.................................. 0 clients
    SNR   30 dB.................................. 0 clients
    SNR   35 dB.................................. 1 clients
    SNR   40 dB.................................. 1 clients
    SNR   45 dB.................................. 4 clients
  Nearby APs
    AP 84:78:ac:b8:32:e0 slot 0..................  -75 dBm on  11 (xxx.xxx.xxx.xxx)
  Radar Information
  Channel Assignment Information
    Current Channel Average Energy...............  -80 dBm
    Previous Channel Average Energy..............  -53 dBm
    Channel Change Count......................... 2
    Last Channel Change Time..................... Sun May 26 02:05:34 2013
    Recommended Best Channel..................... 11
  RF Parameter Recommendations
    Power Level.................................. 1
    RTS/CTS Threshold............................ 2347
    Fragmentation Threshold...................... 2346
    Antenna Pattern.............................. 0
  Persistent Interference Devices
  Class Type                 Channel  DC (%%)  RSSI (dBm)  Last Update Time
  All third party trademarks are the property of their respective owners.
  Slot ID........................................ 1
  Radio Type..................................... RADIO_TYPE_80211a
  Noise Information
    Channel 36...................................  -94 dBm
    Channel 40...................................  -94 dBm
    Channel 44...................................  -94 dBm
    Channel 48...................................  -94 dBm
    Channel 52...................................  -94 dBm
    Channel 56...................................  -94 dBm
    Channel 60...................................  -93 dBm
    Channel 64...................................  -94 dBm
    Channel 149..................................  -92 dBm
    Channel 153..................................  -88 dBm
    Channel 157..................................  -92 dBm
    Channel 161..................................  -92 dBm
    Channel 165..................................  -91 dBm
    Channel 36................................... -128 dBm @  0 % busy
    Channel 40................................... -128 dBm @  0 % busy
    Channel 44................................... -128 dBm @  0 % busy
    Channel 48................................... -128 dBm @  0 % busy
    Channel 52................................... -128 dBm @  0 % busy
    Channel 56................................... -128 dBm @  0 % busy
    Channel 60................................... -128 dBm @  0 % busy
    Channel 64................................... -128 dBm @  0 % busy
    Channel 149.................................. -128 dBm @  0 % busy
    Channel 153.................................. -128 dBm @  0 % busy
    Channel 157.................................. -128 dBm @  0 % busy
    Channel 161.................................. -128 dBm @  0 % busy
    Channel 165.................................. -128 dBm @  0 % busy
    Rogue Histogram (20/40_ABOVE/40_BELOW)
    Channel 36...................................  0/ 0/ 0
    Channel 40...................................  0/ 0/ 0
    Channel 44...................................  0/ 0/ 0
    Channel 48...................................  0/ 0/ 0
    Channel 52...................................  0/ 0/ 0
    Channel 56...................................  0/ 0/ 0
    Channel 60...................................  0/ 0/ 0
    Channel 64...................................  0/ 0/ 0
    Channel 149..................................  0/ 0/ 0
    Channel 153..................................  0/ 0/ 0
    Channel 157..................................  0/ 0/ 0
    Channel 161..................................  0/ 0/ 0
    Channel 165..................................  0/ 0/ 0
  Load Information
    Transmit Utilization......................... 0 %
    Channel Utilization.......................... 0 %
    Attached Clients............................. 0 clients
    RSSI  -60 dbm................................ 0 clients
    RSSI  -52 dbm................................ 0 clients
    SNR   35 dB.................................. 0 clients
    SNR   40 dB.................................. 0 clients
    SNR   45 dB.................................. 0 clients
  Nearby APs
  Radar Information
    Current Channel Average Energy............... unknown
    Previous Channel Average Energy.............. unknown
    Channel Change Count......................... 0
    Last Channel Change Time..................... Wed May 22 20:23:05 2013
    Recommended Best Channel..................... 36
AP Name.......................................... HO_4th_Floor
  Noise Information
    Channel 2....................................  -94 dBm
    Channel 3....................................  -96 dBm
    Channel 5....................................  -94 dBm
    Channel 9....................................  -94 dBm
    Channel 10...................................  -97 dBm
    Channel 11...................................  -92 dBm
  Load Information
    Transmit Utilization......................... 6 %
    Channel Utilization.......................... 7 %
  Nearby APs
    AP 1c:e6:c7:1c:d9:90 slot 0..................  -91 dBm on   1 (xxx.xxx.xxx.xxx)
  Radar Information
    Last Channel Change Time..................... Wed May 22 20:23:08 2013
  Noise Information
    Channel 40...................................  -96 dBm
    Channel 44...................................  -95 dBm
    Channel 52...................................  -95 dBm
    Channel 60...................................  -96 dBm
    Channel 149..................................  -94 dBm
    Channel 153..................................  -85 dBm
    Channel 157..................................  -91 dBm
    Channel 161..................................  -91 dBm
    Channel 165..................................  -92 dBm
  Load Information
    Channel Utilization.......................... 1 %
  Nearby APs
  Radar Information
    Recommended Best Channel..................... 149
AP Name.......................................... HO_6th_Floor
  Noise Information
    Channel 2....................................  -93 dBm
    Channel 7....................................  -95 dBm
    Channel 11...................................  -96 dBm
  Load Information
    Transmit Utilization......................... 9 %
    Channel Utilization.......................... 10 %
    Attached Clients............................. 11 clients
    RSSI  -76 dbm................................ 2 clients
    RSSI  -68 dbm................................ 6 clients
    RSSI  -52 dbm................................ 3 clients
    SNR   20 dB.................................. 1 clients
    SNR   25 dB.................................. 1 clients
    SNR   30 dB.................................. 5 clients
    SNR   45 dB.................................. 2 clients
  Nearby APs
    AP 1c:e6:c7:1c:d9:90 slot 0..................  -82 dBm on   1 (xxx.xxx.xxx.xxx)
  Radar Information
    Last Channel Change Time..................... Wed May 22 20:23:09 2013
  Noise Information
    Channel 48...................................  -95 dBm
    Channel 149..................................  -91 dBm
    Channel 153..................................  -83 dBm
  Load Information
    Failed Clients............................... 1 clients
    RSSI  -84 dbm................................ 1 clients
    SNR   10 dB.................................. 1 clients
  Nearby APs
  Radar Information
    Recommended Best Channel..................... 44
AP Name.......................................... HO_5th_Floor
  Noise Information
  Load Information
    Channel Utilization.......................... 21 %
    Attached Clients............................. 8 clients
    RSSI  -76 dbm................................ 1 clients
    RSSI  -68 dbm................................ 2 clients
    RSSI  -60 dbm................................ 3 clients
    RSSI  -52 dbm................................ 2 clients
    SNR   25 dB.................................. 2 clients
    SNR   30 dB.................................. 1 clients
    SNR   35 dB.................................. 2 clients
    SNR   45 dB.................................. 1 clients
  Nearby APs
    AP 84:78:ac:b8:34:00 slot 0..................  -88 dBm on  11 (xxx.xxx.xxx.xxx)
  Radar Information
    Current Channel Average Energy...............  -82 dBm
    Previous Channel Average Energy..............  -52 dBm
    Channel Change Count......................... 3
    Last Channel Change Time..................... Mon May 27 10:34:23 2013
  Noise Information
    Channel 56...................................  -93 dBm
    Channel 149..................................  -93 dBm
    Channel 157..................................  -93 dBm
    Channel 165..................................  -93 dBm
  Load Information
    Attached Clients............................. 1 clients
    RSSI  -52 dbm................................ 1 clients
    SNR    0 dB.................................. 1 clients
  Nearby APs
  Radar Information
    Last Channel Change Time..................... Wed May 22 20:23:27 2013
    Recommended Best Channel..................... 161
AP Name.......................................... HO_2nd_Floor
  Noise Information
    Channel 4....................................  -96 dBm
  Load Information
    Load Profile................................. FAILED
    Channel Utilization.......................... 17 %
    Attached Clients............................. 13 clients
    RSSI  -68 dbm................................ 1 clients
    RSSI  -60 dbm................................ 4 clients
    RSSI  -52 dbm................................ 7 clients
    SNR   15 dB.................................. 1 clients
    SNR   35 dB.................................. 3 clients
    SNR   40 dB.................................. 3 clients
    SNR   45 dB.................................. 5 clients
  Nearby APs
    AP 84:78:ac:b8:34:d0 slot 0..................  -77 dBm on  11 (xxx.xxx.xxx.xxx)
  Radar Information
    Last Channel Change Time..................... Fri May 24 16:54:06 2013
  Noise Information
    Channel 40...................................  -93 dBm
    Channel 48...................................  -93 dBm
    Channel 60...................................  -94 dBm
    Channel 149..................................  -90 dBm
    Channel 153..................................  -80 dBm
    Channel 157..................................  -89 dBm
    Channel 161..................................  -88 dBm
    Channel 165..................................  -89 dBm
    Channel 149..................................  1/ 0/ 0
  Load Information
    RSSI  -60 dbm................................ 1 clients
  Nearby APs
  Radar Information
    Recommended Best Channel..................... 48
AP Name.......................................... APECC8.82BA.C418
  Noise Information
  Load Information
  Noise Information
  Load Information
AP Name.......................................... Unit1
  Noise Information
    Channel 2....................................  -96 dBm
    Channel 6....................................  -96 dBm
    Channel 8....................................  -96 dBm
    Channel 9....................................  -96 dBm
  Load Information
    Channel Utilization.......................... 6 %
  Nearby APs
  Radar Information
    Last Channel Change Time..................... Thu May 30 03:07:31 2013
  Noise Information
    Channel 40...................................  -95 dBm
    Channel 64...................................  -93 dBm
    Channel 153..................................  -91 dBm
    Channel 161..................................  -93 dBm
    Channel 40...................................  -67 dBm @  1 % busy
  Load Information
  Nearby APs
  Radar Information
AP Name.......................................... Pelhar_IT
  Noise Information
    Channel 1....................................  -94 dBm
    Channel 4....................................  -94 dBm
    Channel 8....................................  -94 dBm
    Channel 10...................................  -94 dBm
    Channel 1....................................  -19 dBm @  1 % busy
    Channel 6....................................  -58 dBm @  2 % busy
  Load Information
    Transmit Utilization......................... 7 %
    Channel Utilization.......................... 23 %
  Nearby APs
  Radar Information
    Last Channel Change Time..................... Thu May 30 10:25:49 2013
  Noise Information
    Channel 36...................................  -92 dBm
    Channel 44...................................  -93 dBm
    Channel 52...................................  -93 dBm
    Channel 60...................................  -95 dBm
    Channel 153..................................  -93 dBm
    Channel 153..................................  1/ 0/ 0
  Load Information
  Nearby APs
  Radar Information
AP Name.......................................... Pelhar_Rcptn
  Noise Information
    Channel 1....................................  -97 dBm
    Channel 2....................................  -97 dBm
    Channel 3....................................  -97 dBm
    Channel 5....................................  -97 dBm
    Channel 6....................................  -97 dBm
    Channel 7....................................  -96 dBm
    Channel 8....................................  -97 dBm
    Channel 9....................................  -97 dBm
    Channel 10...................................  -96 dBm
    Channel 11...................................  -97 dBm
  Load Information
    Channel Utilization.......................... 25 %
  Nearby APs
  Radar Information
    Last Channel Change Time..................... Thu May 30 18:50:42 2013
  Noise Information
    Channel 64...................................  -95 dBm
    Channel 149..................................  -96 dBm
    Channel 157..................................  -94 dBm
    Channel 161..................................  -94 dBm
  Load Information
  Nearby APs
  Radar Information
AP Name.......................................... Pelhar_Admin
  Noise Information
    Channel 1....................................  -96 dBm
    Channel 5....................................  -96 dBm
    Channel 5....................................  -50 dBm @  3 % busy
    Channel 6....................................  -49 dBm @  2 % busy
    Channel 7....................................  -57 dBm @  8 % busy
  Load Information
  Nearby APs
  Radar Information
  Noise Information
    Channel 44...................................  -92 dBm
    Channel 48...................................  -92 dBm
    Channel 52...................................  -92 dBm
    Channel 56...................................  -92 dBm
    Channel 60...................................  -92 dBm
    Channel 64...................................  -92 dBm
    Channel 153..................................  -92 dBm
  Load Information
  Nearby APs
  Radar Information
    Recommended Best Channel..................... 153
802.11a Configuration
802.11a Network.................................. Enabled
11nSupport....................................... Enabled
      802.11a Low Band........................... Enabled
      802.11a Mid Band........................... Enabled
      802.11a High Band.......................... Enabled
802.11a Operational Rates
    802.11a 6M Rate.............................. Mandatory
    802.11a 9M Rate.............................. Supported
    802.11a 12M Rate............................. Mandatory
    802.11a 18M Rate............................. Supported
    802.11a 24M Rate............................. Mandatory
    802.11a 36M Rate............................. Supported
    802.11a 48M Rate............................. Supported
    802.11a 54M Rate............................. Supported
802.11n MCS Settings:
    MCS 0........................................ Supported
    MCS 1........................................ Supported
    MCS 2........................................ Supported
    MCS 3........................................ Supported
    MCS 4........................................ Supported
    MCS 5........................................ Supported
    MCS 6........................................ Supported
    MCS 7........................................ Supported
    MCS 8........................................ Supported
    MCS 9........................................ Supported
    MCS 10....................................... Supported
    MCS 11....................................... Supported
    MCS 12....................................... Supported
    MCS 13....................................... Supported
    MCS 14....................................... Supported
    MCS 15....................................... Supported
    MCS 16....................................... Supported
    MCS 17....................................... Supported
    MCS 18....................................... Supported
    MCS 19....................................... Supported
    MCS 20....................................... Supported
    MCS 21....................................... Supported
    MCS 22....................................... Supported
    MCS 23....................................... Supported
802.11n Status:
    A-MPDU Tx:
        Priority 0............................... Enabled
        Priority 1............................... Disabled
        Priority 2............................... Disabled
        Priority 3............................... Disabled
        Priority 4............................... Enabled
        Priority 5............................... Enabled
        Priority 6............................... Disabled
        Priority 7............................... Disabled
        Aggregation scheduler.................... Enabled
            Realtime Timeout..................... 10
    A-MSDU Tx:
        Priority 1............................... Enabled
        Priority 2............................... Enabled
        Priority 3............................... Enabled
    Rifs Rx ..................................... Enabled
    Guard Interval .............................. Any
Beacon Interval.................................. 100
CF Pollable mandatory............................ Disabled
CF Poll Request mandatory........................ Disabled
CFP Period....................................... 4
CFP Maximum Duration............................. 60
Default Channel.................................. 36
Default Tx Power Level........................... 0
DTPC  Status..................................... Enabled
Fragmentation Threshold.......................... 2346
TI Threshold..................................... -50
Legacy Tx Beamforming setting.................... Disabled
Traffic Stream Metrics Status.................... Disabled
Expedited BW Request Status...................... Disabled
World Mode....................................... Enabled
EDCA profile type................................ default-wmm
Voice MAC optimization status.................... Disabled
Call Admission Control (CAC) configuration
Voice AC:
   Voice AC - Admission control (ACM)............ Disabled
   Voice Stream-Size............................. 84000
   Voice Max-Streams............................. 2
   Voice max RF bandwidth........................ 75
   Voice reserved roaming bandwidth.............. 6
   Voice CAC Method ............................. Load-Based
   Voice tspec inactivity timeout................ Disabled
CAC SIP-Voice configuration
   SIP based CAC ................................ Disabled
   SIP Codec Type ............................... CODEC_TYPE_G711
   SIP call bandwidth ........................... 64
   SIP call bandwith sample-size ................ 20
Video AC:
   Video AC - Admission control (ACM)............ Disabled
   Video max RF bandwidth........................ Infinite
   Video reserved roaming bandwidth.............. 0
   Video load-based CAC mode..................... Disabled
   Video CAC Method ............................. Static
CAC SIP-Video Configuration
   Best-effort AC - Admission control (ACM)...... Disabled
   Background AC - Admission control (ACM)....... Disabled
Maximum Number of Clients per AP Radio........... 200
802.11a Advanced Configuration
Member RRM Information
AP Name                          MAC Address       Admin    Oper        Channel    TxPower
HO_3rd_Floor                     84:78:ac:b8:34:d0 ENABLED  UP          36*        *1/6 (14 dBm)
HO_4th_Floor                     1c:e6:c7:1c:dc:c0 ENABLED  UP          149*       *1/7 (17 dBm)
HO_6th_Floor                     84:78:ac:b8:34:00 ENABLED  UP          44*        *1/7 (17 dBm)
HO_5th_Floor                     1c:e6:c7:1c:d9:90 ENABLED  UP          161*       *1/7 (17 dBm)
HO_2nd_Floor                     84:78:ac:b8:32:e0 ENABLED  UP          48*        *1/7 (17 dBm)
APECC8.82BA.C418                 00:3a:9a:e5:c7:20 ENABLED  UP          149*       *1/4 (16 dBm)
Unit1                            1c:e6:c7:1c:6d:50 ENABLED  UP          36*        *1/7 (14 dBm)
Pelhar_IT                        1c:e6:c7:1c:d9:40 ENABLED  UP          149*       *1/7 (17 dBm)
Pelhar_Rcptn                     1c:e6:c7:1c:da:00 ENABLED  UP          44*        *1/7 (17 dBm)
Pelhar_Admin                     84:78:ac:b8:34:40 ENABLED  UP          153*       *1/7 (17 dBm)
802.11a Airewave Director Configuration
RF Event and Performance Logging
  Channel Update Logging......................... Off
  Coverage Profile Logging....................... Off
  Foreign Profile Logging........................ Off
  Load Profile Logging........................... Off
  Noise Profile Logging.......................... Off
  Performance Profile Logging.................... Off
  TxPower Update Logging......................... Off
Default 802.11a AP performance profiles
  802.11a Global Interference threshold.......... 10 %
  802.11a Global noise threshold................. -70 dBm
  802.11a Global RF utilization threshold........ 80 %
  802.11a Global throughput threshold............ 1000000 bps
  802.11a Global clients threshold............... 12 clients
Default 802.11a AP monitoring
  802.11a Monitor Mode........................... enable
  802.11a Monitor Mode for Mesh AP Backhaul...... disable
  802.11a Monitor Channels....................... Country channels
  802.11a RRM Neighbor Discover Type............. Transparent
  802.11a AP Coverage Interval................... 180 seconds
  802.11a AP Load Interval....................... 60 seconds
  802.11a AP Noise Interval...................... 180 seconds
  802.11a AP Signal Strength Interval............ 60 seconds
  802.11a AP Neighbor Report Interval............ 180 seconds
  802.11a AP Interference Report Interval........ 120 seconds
Leader Automatic Transmit Power Assignment
  Transmit Power Assignment Mode................. AUTO
  Transmit Power Update Interval................. 600 seconds
  Transmit Power Threshold....................... -70 dBm
  Transmit Power Neighbor Count.................. 3 APs
  Min Transmit Power............................. -10 dBm
  Max Transmit Power............................. 30 dBm
  Transmit Power Update Contribution............. SNI..
  Transmit Power Assignment Leader............... CLASSICWLC (xxx.xxx.xxx.xxx)
  Last Run....................................... 29 seconds ago
  TPC Mode....................................... Version 1
  TPCv2 Target RSSI.............................. -67 dBm
  TPCv2 VoWLAN Guide RSSI........................ -67.0 dBm
  TPCv2 SOP...................................... -85.0 dBm
  TPCv2 Default Client Ant Gain..................   0.0 dBi
  TPCv2 Path Loss Decay Factor...................   3.6
  TPCv2 Search Intensity......................... 10 Iterations
AP Name                          Channel    TxPower       Allowed Power Levels
HO_3rd_Floor                     *36        *1/6 (14 dBm) [14/11/8/5/2/-1/0/0]
HO_4th_Floor                     *149       *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
HO_6th_Floor                     *44        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
HO_5th_Floor                     *161       *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
HO_2nd_Floor                     *48        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
APECC8.82BA.C418                 *149       *1/4 (16 dBm) [16/13/10/8/8/8/8/8]
Unit1                            *36        *1/7 (14 dBm) [14/11/8/5/2/-1/-1/0]
Pelhar_IT                        *149       *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
Pelhar_Rcptn                     *44        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
Pelhar_Admin                     *153       *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
Coverage Hole Detection
  802.11a Coverage Hole Detection Mode........... Enabled
  802.11a Coverage Voice Packet Count............ 100 packets
  802.11a Coverage Voice Packet Percentage....... 50%
  802.11a Coverage Voice RSSI Threshold.......... -80 dBm
  802.11a Coverage Data Packet Count............. 50 packets
  802.11a Coverage Data Packet Percentage........ 50%
  802.11a Coverage Data RSSI Threshold........... -80 dBm
  802.11a Global coverage exception level........ 25 %
  802.11a Global client minimum exception lev.... 3 clients
Leader Automatic Channel Assignment
  Channel Assignment Mode........................ AUTO
  Channel Update Interval........................ 600 seconds
  Anchor time (Hour of the day).................. 0
  Channel Update Contribution.................... SNI..
  CleanAir Event-driven RRM option............... Disabled
  CleanAir Event-driven RRM sensitivity.......... Medium
  Channel Assignment Leader...................... CLASSICWLC (xxx.xxx.xxx.xxx)
  DCA Sensitivity Level.......................... MEDIUM (15 dB)
  DCA 802.11n Channel Width...................... 20 MHz
  DCA Minimum Energy Limit....................... -95 dBm
  Channel Energy Levels
    Minimum...................................... unknown
    Average...................................... unknown
    Maximum...................................... unknown
  Channel Dwell Times
    Minimum...................................... 0 days, 15 h 09 m 21 s
    Average...................................... 4 days, 15 h 45 m 36 s
    Maximum...................................... 8 days, 13 h 36 m 58 s
  802.11a 5 GHz Auto-RF Channel List
    Allowed Channel List......................... 36,40,44,48,52,56,60,64,149,
                                                  153,157,161
    Unused Channel List.......................... 165,169,173
  DCA Outdoor AP option.......................... Disabled
Radio RF Grouping
  802.11a Group Mode............................. AUTO
  802.11a Group Update Interval.................. 600 seconds
  802.11a Group Leader........................... CLASSICWLC (xxx.xxx.xxx.xxx)
    802.11a Group Member......................... CLASSICWLC (xxx.xxx.xxx.xxx)
  802.11a Last Run............................... 17 seconds ago
802.11a CleanAir Configuration
Clean Air Solution............................... Disabled
Air Quality Settings:
    Air Quality Reporting........................ Enabled
    Air Quality Reporting Period (min)........... 15
    Air Quality Alarms........................... Enabled
      Air Quality Alarm Threshold................ 35
      Unclassified Interference.................. Disabled
      Unclassified Severity Threshold............ 20
Interference Device Settings:
    Interference Device Reporting................ Enabled
    Interference Device Types:
        TDD Transmitter.......................... Enabled
        Jammer................................... Enabled
        Continuous Transmitter................... Enabled
        DECT-like Phone.......................... Enabled
        Video Camera............................. Enabled
        WiFi Inverted............................ Enabled
        WiFi Invalid Channel..................... Enabled
        SuperAG.................................. Enabled
        Canopy................................... Enabled
        WiMax Mobile............................. Enabled
        WiMax Fixed.............................. Enabled
    Interference Device Alarms................... Enabled
    Interference Device Types Triggering Alarms:
        TDD Transmitter.......................... Disabled
        Continuous Transmitter................... Disabled
        DECT-like Phone.......................... Disabled
        Video Camera............................. Disabled
        SuperAG.................................. Disabled
        Canopy................................... Disabled
        WiMax Mobile............................. Disabled
        WiMax Fixed.............................. Disabled
Additional Clean Air Settings:
    CleanAir ED-RRM State........................ Disabled
    CleanAir ED-RRM Sensitivity.................. Medium
    CleanAir ED-RRM Custom Threshold............. 50
    CleanAir Persistent Devices state............ Disabled
    CleanAir Persistent Device Propagation....... Disabled
802.11a CleanAir AirQuality Summary
AQ = Air Quality
DFS = Dynamic Frequency Selection
AP Name            Channel Avg AQ Min AQ Interferers DFS
802.11b Configuration
802.11b Network.................................. Enabled
11gSupport....................................... Enabled
802.11b/g Operational Rates
    802.11b/g 1M Rate............................ Mandatory
    802.11b/g 2M Rate............................ Mandatory
    802.11b/g 5.5M Rate.......................... Mandatory
    802.11b/g 11M Rate........................... Mandatory
    802.11g 6M Rate.............................. Supported
    802.11g 9M Rate.............................. Supported
    802.11g 12M Rate............................. Supported
    802.11g 18M Rate............................. Supported
    802.11g 24M Rate............................. Supported
    802.11g 36M Rate............................. Supported
    802.11g 48M Rate............................. Supported
    802.11g 54M Rate............................. Supported
802.11n Status:
    A-MPDU Tx:
    A-MSDU Tx:
CF Pollable mode................................. Disabled
Default Channel.................................. 1
Call Admission Limit  ........................... 105
G711 CU Quantum ................................. 15
ED Threshold..................................... -50
PBCC mandatory................................... Disabled
RTS Threshold.................................... 2347
Short Preamble mandatory......................... Enabled
Short Retry Limit................................ 7
Faster Carrier Tracking Loop..................... Disabled
   Voice CAC Method.............................. Load-Based
   SIP call bandwidth: .......................... 64
   SIP call bandwidth sample-size ............... 20
CAC SIP-Video configuration
Maximum Number of Clients per AP................. 200
802.11b Advanced Configuration
HO_3rd_Floor                     84:78:ac:b8:34:d0 ENABLED  UP          11*        *1/7 (17 dBm)
HO_4th_Floor                     1c:e6:c7:1c:dc:c0 ENABLED  UP          1*         *1/7 (17 dBm)
HO_6th_Floor                     84:78:ac:b8:34:00 ENABLED  UP          11*        *1/7 (17 dBm)
HO_5th_Floor                     1c:e6:c7:1c:d9:90 ENABLED  UP          1*         *1/7 (17 dBm)
HO_2nd_Floor                     84:78:ac:b8:32:e0 ENABLED  UP          11*        *1/7 (17 dBm)
APECC8.82BA.C418                 00:3a:9a:e5:c7:20 ENABLED  UP          1*         *1/5 (19 dBm)
Unit1                            1c:e6:c7:1c:6d:50 ENABLED  UP          11*        *1/7 (17 dBm)
Pelhar_IT                        1c:e6:c7:1c:d9:40 ENABLED  UP          11*        *1/7 (17 dBm)
Pelhar_Rcptn                     1c:e6:c7:1c:da:00 ENABLED  UP          11*        *1/7 (17 dBm)
Pelhar_Admin                     84:78:ac:b8:34:40 ENABLED  UP          11*        *1/7 (17 dBm)
802.11b Airewave Director Configuration
  Transmit Power Update Logging.................. Off
Default 802.11b AP performance profiles
  802.11b Global Interference threshold.......... 10 %
  802.11b Global noise threshold................. -70 dBm
  802.11b Global RF utilization threshold........ 80 %
  802.11b Global throughput threshold............ 1000000 bps
  802.11b Global clients threshold............... 12 clients
Default 802.11b AP monitoring
  802.11b Monitor Mode........................... enable
  802.11b Monitor Channels....................... Country channels
  802.11b RRM Neighbor Discovery Type............ Transparent
  802.11b AP Coverage Interval................... 180 seconds
  802.11b AP Load Interval....................... 60 seconds
  802.11b AP Noise Interval...................... 180 seconds
  802.11b AP Signal Strength Interval............ 60 seconds
  802.11b AP Neighbor Report Interval............ 180 seconds
  802.11b AP Interference Report Interval........ 120 seconds
  Last Run....................................... 44 seconds ago
HO_3rd_Floor                     *11        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
HO_4th_Floor                     *1         *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
HO_6th_Floor                     *11        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
HO_5th_Floor                     *1         *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
HO_2nd_Floor                     *11        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
APECC8.82BA.C418                 *1         *1/5 (19 dBm) [19/16/13/10/8/8/8/8]
Unit1                            *11        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
Pelhar_IT                        *11        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
Pelhar_Rcptn                     *11        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
Pelhar_Admin                     *11        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
  802.11b Coverage Hole Detection Mode........... Enabled
  802.11b Coverage Voice Packet Count............ 100 packets
  802.11b Coverage Voice Packet Percentage....... 50%
  802.11b Coverage Voice RSSI Threshold.......... -80 dBm
  802.11b Coverage Data Packet Count............. 50 packets
  802.11b Coverage Data Packet Percentage........ 50%
  802.11b Coverage Data RSSI Threshold........... -80 dBm
  802.11b Global coverage exception level........ 25 %
  802.11b Global client minimum exception lev.... 3 clients
  DCA Sensitivity Level: ...................... MEDIUM (10 dB)
    Minimum...................................... -82 dBm
    Average...................................... -81 dBm
    Maximum...................................... -80 dBm
  Channel Dwell Times
    Minimum...................................... 0 days, 15 h 09 m 24 s
    Average...................................... 3 days, 20 h 58 m 18 s
  802.11b Auto-RF Allowed Channel List........... 1,6,11
  Auto-RF Unused Channel List.................... 2,3,4,5,7,8,9,10
Radio RF Grouping
  802.11b Group Mode............................. AUTO
  802.11b Group Update Interval.................. 600 seconds
  802.11b Group Leader........................... CLASSICWLC (xxx.xxx.xxx.xxx)
    802.11b Group Member......................... CLASSICWLC (xxx.xxx.xxx.xxx)
  802.11b Last Run............................... 32 seconds ago
        Bluetooth Link........................... Enabled
        Microwave Oven........................... Enabled
        802.11 FH................................ Enabled
        Bluetooth Discovery...................... Enabled
        802.15.4................................. Enabled
        Microsoft Device......................... Enabled
        Bluetooth Link........................... Disabled
        Microwave Oven........................... Disabled
        802.11 FH................................ Disabled
        Bluetooth Discovery...................... Disabled
        802.15.4................................. Disabled
        Microsoft Device......................... Disabled
AQ = Air Quality
Mobility Configuration
Mobility Architecture ........................... Flat
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... CLASSIC
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0xab3c
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 1
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
MAC Address        IP Address       Group Name                        Multicast IP     Status
6c:20:56:b8:96:60  xxx.xxx.xxx.xxx     CLASSIC                           0.0.0.0          Up
Mobility Hash Configuration
IP Address      Hash Key
Self Signed Certificate details
SSC Hash validation.............................. Enabled.
SSC device certificate not present.
Mobility Foreign Map Configuration
WLAN ID     Foreign Mac Address     Interface
Probe request filtering..........................  Enabled
Probes fwd to controller per client per radio....  2
Probe request rate-limiting interval.............  500 msec
Aggregate Probe request interval.................  500 msec
EAP-Identity-Request Timeout (seconds)........... 30
EAP-Identity-Request Max Retries................. 2
EAP Key-Index for Dynamic WEP.................... 0
EAP Max-Login Ignore Identity Response........... enable
EAP-Request Timeout (seconds).................... 30
EAP-Request Max Retries.......................... 3
EAPOL-Key Timeout (milliseconds)................. 1000
EAPOL-Key Max Retries............................ 2
EAP-Broadcast Key Interval....................... 3600
Fastpath Packet Capture.......................... disable
Fastpath Fast Cache Control...................... enable
Fastpath Fast Testmode........................... 0x0
dot11-padding.................................... Disabled
Advanced Hotspot Commands
ANQP 4-way state................................. Disabled
GARP Broadcast state: ........................... Enabled
GAS request rate limit .......................... Disabled
ANQP comeback delay in TUs(TU=1024usec).......... 50
Location Configuration
RFID Tag data Collection......................... Enabled
RFID  timeout.................................... 1200 seconds
RFID mobility....................................
Interface Configuration
Interface Name................................... management
MAC Address...................................... 6c:20:56:b8:96:60
IP Address....................................... xxx.xxx.xxx.xxx
IP Netmask....................................... 255.255.254.0
IP Gateway....................................... xxx.xxx2.1
External NAT IP State............................ Enabled
External NAT IP Address.......................... 119.226.7.192
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. 2
Primary DHCP Server.............................. xxx.xxx1.13
Secondary DHCP Server............................ xxx.xxx1.5
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Disabled
Interface Name................................... virtual
IP Address....................................... 10.60.60.1
Virtual DNS Host Name............................ Disabled
AP Manager....................................... No
Interface Group Configuration
WLAN Configuration
WLAN Identifier.................................. 1
Profile Name..................................... CSPL_Wifi
Network Name (SSID).............................. CSPL_Wifi
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Enabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 35
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream    Downstream
Average Data Rate................................   0          0
Average Realtime Data Rate.......................   0          0
Burst Data Rate..................................   0          0
Burst Realtime Data Rate.........................   0          0
Per-Client Rate Limits........................... Upstream    Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ xxx.xxx1.7 1812
   Accounting.................................... xxx.xxx1.7 1813
      Interim Update............................. Disabled
   Dynamic Interface............................. Enabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Enabled
      Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Enabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Enabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
WLAN Configuration
WLAN Identifier.................................. 2
Profile Name..................................... CSPL_Guest
Network Name (SSID).............................. CSPL_Guest
AAA Policy Override.............................. Disabled
Number of Active Clients......................... 2
Session Timeout.................................. Infinity
WLAN IPv4 ACL.................................... Guest_Logon
Peer-to-Peer Blocking Action..................... Drop
Radius Servers
   Authentication................................ Disabled
   Accounting.................................... Disabled
   Dynamic Interface............................. Disabled
Security
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   Web Based Authentication...................... Enabled
    IPv4 ACL........................................ Before_Logon
    IPv6 ACL........................................ Unconfigured
    Web-Auth Flex ACL............................... Unconfigured
    Web Authentication server precedence:
    1............................................... local
   FlexConnect Local Switching................... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Disabled
   Client MFP.................................... Optional but inactive (WPA2 not configured)
WLAN Configuration
WLAN Identifier.................................. 3
Profile Name..................................... CSPL_Wifi_T
Network Name (SSID).............................. CSPL_Wifi_T
Number of Active Clients......................... 6
Radius Servers
Security
         TKIP Cipher............................. Disabled
      Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
ACL Configuration
ACL name: Guest_Logon
                       Source                         Destination                 Source Port  Dest Port
Index  Dir       IP Address/Netmask               IP Address/Netmask       Prot    Range       Range    DSCP  Action      Counter
     1 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0            6     0-65535    80-80     Any Permit      284149
     2 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0            6     0-65535   443-443    Any Permit      313663
     3 Any         0.0.0.0/0.0.0.0            xxx.xxx1.13/255.255.255.255  Any     0-65535     0-65535  Any Permit       19356
     4 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0           17     0-65535    68-68     Any Permit           0
     5 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0           17     0-65535    53-53     Any Permit        6128
     6 Any         0.0.0.0/0.0.0.0             xxx.xxx2.1/255.255.255.255  Any     0-65535     0-65535  Any Permit        1167
     7 Any         0.0.0.0/0.0.0.0             xxx.xxx2.4/255.255.255.255  Any     0-65535     0-65535  Any Permit           0
     8 Any         0.0.0.0/0.0.0.0             xxx.xxx0.0/255.255.255.0    Any     0-65535     0-65535  Any   Deny          81
     9 Any         0.0.0.0/0.0.0.0             xxx.xxx1.0/255.255.255.0    Any     0-65535     0-65535  Any   Deny        8910
    10 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0          Any     0-65535     0-65535  Any Permit    40670301
ACL name: Before_Logon
     1 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0           17     0-65535    68-68     Any Permit           0
     2 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0            6     0-65535    68-68     Any Permit           0
     3 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0           17     0-65535    53-53     Any Permit       87499
     4 Any         0.0.0.0/0.0.0.0             xxx.xxx2.4/255.255.255.255  Any     0-65535     0-65535  Any Permit           1
     5 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0          Any     0-65535     0-65535  Any   Deny     3156092
CPU ACL Configuration
CPU Acl Name................................ NOT CONFIGURED
Wireless Traffic............................ Disabled
Wired Traffic............................... Disabled
RADIUS Configuration
Vendor Id Backward Compatibility................. Disabled
Call Station Id Case............................. lower
Call Station Id Type............................. IP Address
Aggressive Failover.............................. Enabled
Keywrap.......................................... Disabled
Fallback Test:
    Test Mode.................................... Off
    Probe User Name.............................. cisco-probe
    Interval (in seconds)........................ 300
MAC Delimiter for Authentication Messages........ hyphen
MAC Delimiter for Accounting Messages............ hyphen
Authentication Servers
Idx  Type  Server Address    Port    State     Tout  MgmtTout  RFC3576  IPSec - AuthMode/Phase1/Group/Lifetime/Auth/Encr
1    NM    xxx.xxx1.7       1812    Enabled   2     2         Enabled   Disabled - none/unknown/group-0/0 none/none
Accounting Servers
1      N     xxx.xxx1.7       1813    Enabled   2     2         N/A       Disabled - none/unknown/group-0/0 none/none
TACACS Configuration
Idx  Server Address    Port    State     Tout  MgmtTout
Authorization Servers
Accounting Servers
LDAP Configuration
Local EAP Configuration
User credentials database search order:
    Primary ..................................... Local DB
Timer:
    Active timeout .............................. 300
Configured EAP profiles:
    Name ........................................ CSPL
      Certificate issuer ........................ cisco
      Peer verification options:
        Check against CA certificates ........... Enabled
        Verify certificate CN identity .......... Disabled
        Check certificate date validity ......... Enabled
      EAP-FAST configuration:
        Local certificate required .............. No
        Client certificate required ............. Yes
      Enabled methods ........................... peap
      Configured on WLANs ....................... none
EAP Method configuration:
    EAP-FAST:
      Server key ................................
      TTL for the PAC ........................... 10
      Anonymous provision allowed ............... Yes
      Authority ID .............................. 436973636f0000000000000000000000
      Authority Information ..................... Cisco A-ID
FlexConnect Group Summary
FlexConnect Group Summary: Count: 0
Group Name                # Aps
FlexConnect Group Detail
Route  Info
Number of Routes................................. 0
Destination Network          Netmask               Gateway
Peer Route  Info
Qos Queue Length Info
Platinum queue length............................ 100
Gold queue length................................  75
Silver queue length..............................  50
Bronze queue length..............................  25
Mac Filter Info
Authorization List
Authorize MIC APs against AAA ................... disabled
Authorize LSC APs against Auth-List ............. disabled
APs Allowed to Join
  AP with Manufacturing Installed Certificate.... yes
  AP with Self-Signed Certificate................ no
  AP with Locally Significant Certificate........ no
Load Balancing Info
Aggressive Load Balancing........................ per WLAN enabling
Aggressive Load Balancing Window................. 5 clients
Aggressive Load Balancing Denial Count........... 3
Statistics
Total Denied Count............................... 0 clients
Total Denial Sent................................ 0 messages
Exceeded Denial Max Limit Count.................. 0 times
None 5G Candidate Count.......................... 0 times
None 2.4G Candidate Count........................ 0 times
DHCP Info
No leases allocated.
DHCP Opt-82 RID Format:
DHCP Opt-82 Format: binary
DHCP Proxy Behaviour:    enabled
DHCP Server IP Address:.......................... xxx.xxx1.5
  DHCP DISCOVER Count:........................... 5305
  DHCP REQUEST Count:............................ 37240
  DHCP INFORM Count:............................. 68829
  DHCP DECLINE Count:............................ 0
  DHCP RELEASE Count:............................ 143
  DHCP REPLY Count:.............................. 0
  DHCP OFFER Count:.............................. 5231
  DHCP ACK Count:................................ 105364
  DHCP NAK Count:................................ 0
  Tx Fails:...................................... 0
  Last Rx Time:.................................. 2 seconds ago
  Last Tx Time:.................................. 2 seconds ago
DHCP Server IP Address:.......................... xxx.xxx1.13
  DHCP DISCOVER Count:........................... 3670
  DHCP REQUEST Count:............................ 8981
  DHCP INFORM Count:............................. 0
  DHCP RELEASE Count:............................ 0
  DHCP OFFER Count:.............................. 0
  DHCP ACK Count:................................ 0
  Last Rx Time:.................................. 0
  Last Tx Time:.................................. 364 seconds ago
Exclusion List Configuration00:16:6f:06:6b:9b
08:08:c2:fd:60:01
1c:ab:a7:2e:42:52
28:cc:01:db:c2:06         Smita's Personal Tab
30:69:4b:f7:14:0c
40:a6:d9:d2:7b:be
58:c3:8b:de:8b:e1
5c:b5:24:b7:98:c9
5c:e2:f4:b9:73:a8
78:59:5e:55:37:ff
88:c6:63:21:cf:fd         Pracena's personal device
a0:75:91:1f:cd:92
d0:b3:3f:7d:5f:ce
e0:ca:94:97:41:2f
CDP Configuration
cdp version v2
Country Channels Configuration
Configured Country............................. IN  - India
      KEY: * = Channel is legal in this country and may be configured manually.
           A = Channel is the Auto-RF default in this country.
           . = Channel is not legal in this country.
           C = Channel has been configured for use by Auto-RF.
           x = Channel is available to be configured for use by Auto-RF.
         (-,-) = (indoor, outdoor) regulatory domain allowed by this country.
    802.11bg     :
    Channels     :                   1 1 1 1 1
                 : 1 2 3 4 5 6 7 8 9 0 1 2 3 4
IN (-A   ,-AN  ): A * * * * A * * * * A . . .
    802.11a      :                         1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
    Channels     : 3 3 3 4 4 4 4 4 5 5 6 6 0 0 0 1 1 2 2 2 3 3 4 4 5 5 6 6 6 7
                 : 4 6 8 0 2 4 6 8 2 6 0 4 0 4 8 2 6 0 4 8 2 6 0 9 3 7 1 5 9 3
IN (-DN  ,-DN  ): . A . A . A . A A A A A . . . . . . . . . . . A A A A * * *
WPS Configuration Summary
Auto-Immune
  Auto-Immune.................................... Disabled
Client Exclusion Policy
  Excessive 802.11-association failures.......... Enabled
  Excessive 802.11-authentication failures....... Enabled
  Excessive 802.1x-authentication................ Enabled
  IP-theft....................................... Enabled
  Excessive Web authentication failure........... Enabled
Signature Policy
  Signature Processing........................... Enabled
Management Frame Protection
  Global Infrastructure MFP state................ DISABLED (*all infrastructure settings are overridden)
  Controller Time Source Valid................... False
                                    WLAN       Client
WLAN ID  WLAN Name                  Status     Protection
1        CSPL_Wifi                  Enabled    Optional
2        CSPL_Guest                 Enabled    Optional but inactive (WPA2 not configured)
3        CSPL_Wifi_T                Enabled    Optional
Custom Web Configuration
Radius Authentication Method..................... PAP
Cisco Logo....................................... Disabled
CustomLogo....................................... None
Custom Title..................................... Welcome to the Classic Stripes Guest Network
Custom Message................................... Please login using the provided Guest credentials!
Custom Redirect URL.............................. None
Web Authentication Type.......................... Internal Default
Logout-popup..................................... Enabled
External Web Authentication URL.................. None
Configuration Per Profile:
WLAN ID: 2
   WLAN Status................................... Enabled
   Web Security Policy........................... Web Based Authentication
   Global Status................................. Disabled
   WebAuth Type.................................. Internal
Core dump Configuration
Core Dump is disabled
Rogue AP Configuration
Rogue on wire Auto-Contain....................... Disabled
Rogue using our SSID Auto-Contain................ Disabled
Valid client on rogue AP Auto-Contain............ Disabled
Rogue AP timeout................................. 1200
Rogue Detection Report Interval.................. 10
Rogue Detection Min Rssi......................... -128
Rogue Detection Transient Interval............... 0
Total Rogues(AP+Ad-hoc) supported................ 2000
Total Rogues classified.......................... 12
MAC Address        Classification     # APs # Clients Last Heard
00:18:eb:01:20:2c  Unclassified       2     0         Fri May 31 10:00:14 2013
00:22:75:55:ed:8c  Unclassified       1     0         Fri May 31 09:51:16 2013
00:3a:98:de:ac:20  Unclassified       2     2         Fri May 31 10:00:26 2013
00:3a:98:df:db:c0  Unclassified       1     0         Fri May 31 09:59:53 2013
00:3a:98:ed:10:e0  Unclassified       2     0         Fri May 31 10:00:14 2013
00:3a:98:f1:96:f0  Unclassified       2     2         Fri May 31 09:57:45 2013
5c:0e:8b:e8:c6:20  Unclassified       1     0         Fri May 31 09:48:50 2013
5c:0e:8b:e8:c6:90  Unclassified       2     0         Fri May 31 09:48:13 2013
74:ea:3a:b0:3d:16  Pending            1     0         Fri May 31 10:00:16 2013
98:fc:11:a8:e0:ef  Unclassified       1     0         Fri May 31 09:40:25 2013
98:fc:11:ab:a9:ad  Unclassified       1     0         Fri May 31 09:51:16 2013
a0:75:91:c2:1b:c5  Malicious          0     0         Not Heard
c8:cb:b8:f3:32:31  Unclassified       2     0         Fri May 31 09:47:54 2013
Adhoc Rogue Configuration
Detect and report Ad-Hoc Networks................ Enabled
Auto-Contain Ad-Hoc Networks..................... Disabled
Total Rogues(Ad-Hoc+AP) supported ............... 2000
Total Ad-Hoc entries ............................ 0
Client MAC Address  Adhoc BSSID         State              # APs   Last Heard
Rogue Client Configuration
Validate rogue clients against AAA............... Disabled
Total Rogue Clients supported.................... 2500
Total Rogue Clients present...................... 4
MAC Address        State              # APs Last Heard
40:61:86:47:19:92  Alert              1     Fri May 31 09:51:14 2013
64:27:37:e8:fb:75  Alert              1     Fri May 31 09:59:55 2013
cc:af:78:a1:7c:0d  Alert              1     Fri May 31 09:42:13 2013
f0:7d:68:5f:67:15  Alert              1     Fri May 31 09:59:55 2013
Ignore List Configuration
MAC Address
Rogue Rule Configuration
Priority Rule Name               State    Type          Match Hit Count
Media-Stream Configuration
Multicast-direct State........................... disable
Allowed WLANs....................................
Stream Name   Start IP                                End IP                                  Operation Status
URL..............................................
E-mail...........................................
Phone............................................
Note.............................................
State............................................ disable
2.4G Band Media-Stream Configuration
Multicast-direct................................. Enabled
Best Effort...................................... Disabled
Video Re-Direct.................................. Enabled
Max Allowed Streams Per Radio.................... Auto
Max Allowed Streams Per Client................... Auto
Max Video Bandwidth.............................. 0
Max Voice Bandwidth.............................. 75
Max Media Bandwidth.............................. 85
Min PHY Rate..................................... 6000
Max Retry Percentage............................. 80
5G Band Media-Stream Configuration
Number of Clients................................ 0
Client Mac         Stream Name  Stream Type  Radio WLAN  QoS    Status
WLC Voice Call Statistics
WLC Voice Call Statistics for 802.11b Radio
WMM TSPEC CAC Call Stats
  Total num of Calls in progress................. 0
  Num of Roam Calls in progress.................. 0
  Total Num of Calls Admitted.................... 0
  Total Num of Roam Calls Admitted............... 0
  Total Num of exp bw requests received.......... 0
  Total Num of exp bw requests Admitted.......... 0
  Total Num of Calls Rejected.................... 0
  Total Num of Roam Calls Rejected............... 0
  Num of Calls Rejected due to insufficent bw.... 0
  Num of Calls Rejected due to invalid params.... 0
  Num of Calls Rejected due to PHY rate.......... 0
  Num of Calls Rejected due to QoS policy........ 0
SIP CAC Call Stats
  Total Num of Calls in progress................. 0
  Total Num of Preferred Calls Received.......... 0
  Total Num of Preferred Calls Admitted.......... 0
  Total Num of Ongoing Preferred Calls........... 0
  Total Num of Calls Rejected(Insuff BW)......... 0
  Total Num of Roam Calls Rejected(Insuff BW).... 0
KTS based CAC Call Stats
WLC Voice Call Statistics for 802.11a Radio
SIP CAC Call Stats
WLC IPv6 Summary
Global Config............................... Enabled
Reachable-lifetime value.................... 300
Stale-lifetime value........................ 86400
Down-lifetime value......................... 30
RA Throttling............................... Disabled
RA Throttling allow at-least................ 1
RA Throttling allow at-most................. 1
RA Throttling max-through................... 10
RA Throttling throttle-period............... 600
RA Throttling interval-option............... passthrough
NS Mulitcast CacheMiss Forwarding........... Disabled
(Cisco Controller) >
Are you able to see any logs on the authetication server?
Also please try to get out of "debug client " from WLC.
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
No logs are generated while connecting to the SSID on WLC. I tried to connect to another SSID broadcasting on the same AP. The logs were generated, but not for the SSID in question.
Akshat Mirgal
Scott Fella
So I see you have 3 SSID's and two of them are using radius authentication. If you look at the configuration between the two radius configured SSID's you will notice the one that works is using WPA2/AES and the one that doesn't (CSPL_Wifi) is using WPA2/TKIP & AES. This is or might be your issue. You need to disable TKIP and just use WPA2/AES.
When using WPA you use TKIP, when using WPA2, you use AES.
Try this and let us know.
-Scott
Thanks a lot Scott
No lproblem
-Scott
