Clients will not connect to 1231G AP
Chris Johnson
Hey guys, I bought 3 of the Aironet 1231g access points and cannot get any clients to connect to them.  I have tried everything from an Iphone, Droid2, Win 7 and XP laptops with built in wireless G cards. All say that they cannot connect to the wireless network. I have two setup currently, one on Vlan 1 that I have configured the way I want with WPA2 enterprise. The other one is just one I setup while playing around.
Surendra BG
Config Looks messed up!! Please change the same like below..
dot11 ssid 2BCMember
   vlan 2
   authentication open
   no guest-mode
   mbssid guest-mode
   no mobility network-id 2
   authentication key-management wpa
   wpa-psk ascii 7 070224414C0C0B5547
dot11 ssid 2BCOffice
   vlan 1
   authentication open eap eap_methods
   authentication network-eap eap_methods
   mbssid guest-mode
   no infrastructure-ssid optional
   no mobility network-id 1
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 2 mode ciphers aes-ccm
Lemme know if this helps and please dont forget to rate the usefull posts!!
Surendra
Surendra BG
Surendra BG
   vlan 2
   authentication open
   no guest-mode
   mbssid guest-mode
   vlan 1
   mbssid guest-mode
no ip address
no ip route-cache
Surendra
Surendra BG
So I'm only changing the parts mentioned in your reply, correct?
yes please!!
Surendra
Surendra BG
Sorry for being late getting back to you on this, it worked! I have gone through the setup from scratch now from the beginning and I think I just tried too much getting it to work, that I just messed it up more. Thanks!
