cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
asosa1
Beginner
Configuracion AIR AP1141N-A-K9
Buenas tardes, una consulta soy nuevo en esto y no puedo configurar el AIR AP1141N-A-K9 no me aparece el comando configure terminal para acceder a la configuracion de las interfaces.
solo me aparecen los siguientes comandos :
ap#?
Exec commands:
access-profile             Apply user-profile to interface
capwap                      capwap exec commands
cd                            Change current directory
clear                         Reset functions
clock                         Manage the system clock
crypto                       Encryption related commands.
debug                       Debugging functions (see also 'undebug')
delete                       Delete a file
dir                            List files on a filesystem
disable                    Turn off privileged commands
do-exec                  Mode-independent "do-exec" prefix support
dot1x                      IEEE 802.1X Exec Commands
eap                         EAP Exec Commands
enable                    Turn on privileged commands
exit                        Exit from the EXEC
fsck                        Fsck a filesystem
help                        Description of the interactive help system
led                        LED functions
lock                     Lock the terminal
logging                 Handles logging operations
login                       Log in as a particular user
logout                        Exit from the EXEC
lwapconfig                  OfficeExtend AP configurations
lwapp                    lwapp exec commands
mkdir                   Create new directory
monitor               Monitoring different system events
more                   Display the contents of a file
name-connection          Name an existing network connection
no                                Disable debugging functions
partition                        Partition disk
ping                          Send echo messages
pwd                             Display current working directory
radius                          radius exec commands
release                       Release a resource
reload                        Halt and perform a cold restart
rename                  Rename a file
renew                     Renew a resource
rmdir                        Remove existing directory
rsh                         Execute a remote command
send                        Send a message to other tty lines
set                          Set system parameter (not config)
show                        Show running system information
ssh                             Open a secure shell client connection
systat                       Display information about terminal lines
terminal                          Set terminal line parameters
test                          Test subsystems, memory, and interfaces
traceroute                Trace route to destination
undebug                 Disable debugging functions (see also 'debug')
upgrade                 Upgrade commands
verify                  Verify a file
where              List active connections
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Hola de nuevo @asosa1
La respuesta es no, Cisco ya no brinda soporte para este modelo de APs
Existe una posibilidad la cual no recomiendo, pero esta posibilidad es buscar en internet el software de tu AP, solo recuerda que cualquier fuente de información o software que no sea propietaria de cisco es un riesgo.
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
Ver la solución en mensaje original publicado
3 RESPUESTAS 3
Hola @asosa1
El problema es que el AP esta en modo capwap, es por ello que el comando "configure Terminal" no esta habilitado. CAPWAP significa que el AP necesita de un controlador para poder funcionar
Es necesario realizar la conversión del AP, sin embargo, ya no hay una imagen que permita trabajar al AP de modo autónomo.
Saludos Cordiales
Disculpe mi ignorancia , eso significa que ya no puedo usar ese AP o hay alguna forma de sacarlo de ese modo capwap
Crear
Reconozca a un colega
Content for Community-Ad
