Configuration of Cisco AIR-AP1832I-A-K9
landro
Hi Team,
I would like to ask you if the Access Point model AIR-AP1832I-A-K9 could be configured as standalone, I mean, not using a wireless controller.
Thank you.
Mark Malone
looks like yes is the answer , when I check the download section there is a lightweight version available for download which would enable it to be standalone , but you will need to convert it first the AP
https://software.cisco.com/download/type.html?mdfid=286288035&flowid=76322 4
how to convert
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_01101110.pdf
That model supports Mobility Express which is a built-in controller. This model along with the 2802 and 3802, do not support autonomous mode.
Here is a ME guide:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-2/b_Mobility_Express_Deployment_guide.html
-Scott
-Scott
Sorry that's my bad got It back to front I though the lightweight was the autonomous been a while since I worked on Cisco wireless , thanks Scott +5
Mark,
Not your fault. I think Cisco moving to ME has caused issue with many customers wanted my am autonomous AP and couldn't.
-Scott
-Scott
