Configuring a Secondary WLC
liamkidd981
I need to configure a secondary virtual WLC that will obviously control the APs if the primary fails. What would be the quickest and best way of configuring it?
Rasika Nayanajith
taking a backup of the existing vWLC configuration & modify the management & any other dynamic interfaces IP (on the same corresponding vlans) if you require to keep both vWLC up any given time.
Then once you build the vWLC with basic configs, you can download the modified configuration.
Refer this to see the CLI commands if you prefer doing this in that way
http://mrncciew.com/2013/01/25/backup-restore-wlc-configs/
Rasika
**** Pls rate all useful responses ***
