08-31-2018 02:32 AM - edited 07-05-2021 09:04 AM
hi all,
I have converted my entire warehouse in wifi zone using Cisco AP.
Now I want to connect a 2 nos IT device installed on the crane, I am able to power it but unable to give lan.
so i want to use bridging concept here.
want to install a Cisco wireless router on the crane and connect two it equipment with LAN with output rj45 port of the wireless router and input rj45 point in it equipment.
configure the wireless router in bridge mode, so that i can connect to AP already installed in the warehouse.
please give your valuable inputs
please suggest cisco wireless router that supports bridging.
08-31-2018 04:58 AM
Which AP model did you use on the warehouse? Why dont you use the same to create the link. Most Cisco AP supports bridge.
-If I helped you somehow, please, rate it as useful.-
08-31-2018 05:05 AM
Dear Flavio ,
my requirement is a device which accepts cisco wifi input and output LAN port 2 nos to connect to IT products.
Resouse AVAILABLE : CISCO enable wireless warehouse
requirment a device :
input : Cisco wirelesss connection
output : LAN CONNECTION TO CONNECT TWO WIRED DEVICE
