Connection on a LAN Wireless
CarOneAdmin
Community Member
Dear all,
i have a doubt with the lan wireless meraky connectivity.
if i lost internet conection, may i can still printing, sharing documents and make connections under
all of my devices? or i lost total connection to everithing?
Regards.
ww^
Meraki Community All-Star
yes you can. But we aware that if when you are using a cloud/internet radius for authentication of ports/wireless connection, and this also is not reachable, you will not be able to get on your network.
ww^
Do you mean the management connection to the cloud?
Your devices keep working without internet but your not able to monitor or push new configurations.
CarOneAdmin
Community Member
ww
maybe i not explain me correctly
i want to know if i lost internet connection what happen with my devices connected?
can i connect to anoher device, connect to a print & share folders, like a cable lan connection?
thanks!
ww^
Philip D'Ath
If you are already connected, you will remain connected and everything will keep working.
