10-23-2008 01:27 PM - edited 07-03-2021 04:40 PM
Can someone confirm for me that using a POE adapter is has a limitation of 100Mbps? I have a AIR-PWRINJ4 and after troubleshooting have determined that I get 1000Mbps connection speed on my 1250 AP until I use it with the POE adapter.
10-24-2008 06:50 AM
No, it should work at Gig. Our one here certainly is.
Check the patch leads are all properly seated.
Log in to Community
