Controller Dot11radio 0 not present in Cisco AP 1250
Luis Ruiz Lopez
Hi @ll,
I've just got a new AP 1250 series, and I was trying to configure the Radio for the 2.4Ghz spectrum using the interface dot11radio 0 and I've just noticed that this controller is not present so I cannot configure it so I wonder is it could be a HW problems as it looks to me or there is another way to enable this.
I never have an issue like this before so I want to first check with you before going back to our vendor.
Here is some of the details I get from the AP itself:
System image file is "flash:/c1250-k9w7-mx.124-10b.JDA3/c1250-k9w7-mx.124-10b.JDA3"
ap02#sh controllers dot11Radio 0
% Invalid input detected at '^' marker.
FrTNFap02#sh inventory
NAME: "AP1210", DESCR: "Cisco Aironet 1200 Series Access Point"
PID: AIR-AP1252AG-E-K9 , VID: V03, SN: FCZ1516P01X
NAME: "Dot11Radio1", DESCR: "802.11N 5Ghz Radio"
PID: AIR-RM1252A-E-K9  , VID: V01, SN: FOC15083NT0
Thank you very much for your assistance.
Luis
George Stefanick
You have a 2.4 GHz radio module installed in the 1252, right? If so, pull it out and reseat it ... Give that a try ..
George Stefanick
Someone went onsite and reseated the module and after that, the radio the controller appeared.
Thanks a lot!
Luis
Leo Laohoo
If it still doesn't work, post the entire bootup process.  Also post the command "dir".
