Controller Not Talking To Prime Properly
wrainwater
I'm experiencing a weird problem. My SNMP string is configured right, but no information is being sent outside of the controller. It works just fine as far as traffic goes. However, when I upload the controller to either cisco prime or solarwinds NPM, I get no wireless information. Does anyone know what I can do to fix this?
Im using a 5760 WLC and Prime Infrastructure 3.2
Rasika Nayanajith
What version of IOS-XE running on your 5760 ?
If you can, try SNMPv3 & see if that makes any difference, see below for guidance
https://mrncciew.com/2014/05/03/cisco-prime-device-mgt-using-snmpv3/
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
thanks for your response. I figured it out. Apparently the prime version im on no longer supports the version my 5760 controller has on it.I just need to get a new controller.
Thanks for the update. What version running on your 5760 ?
Rasika
