01-17-2013 11:44 PM - edited 07-03-2021 11:22 PM
Hi Team,
My customer need creats some separately web portal for some SSID (Guest and Staff), 01 web portal for Guest and 01 Web portal for Staff. Can WLC2504 can support this features ?
Thanks & best Regards,
Lam
01-18-2013 02:01 AM
Yes it can. You need to create and upload 2 HTML files, one for each SSID. The files need to be in a .tar bundle and then needs to be uploaded to the WLC. Then in the WLAN settings, you choose override WebAuth and you pick your HTML file of that particular SSID.
01-18-2013 02:01 AM
Here is a link to a guide also
https://supportforums.cisco.com/docs/DOC-13954#Lets_go_for_custom_
