Create a radio channel alert
DAVID
Level 3
Level 3
Where can I go to create an alert so that Prime will notify me whenever the utilization on either radio interface on a 3700i access points reaches a certain percentage utilization?
Scott Fella
On the controller, you can set the threshold for AP utilization. The default for this trap is 80.  This setting can be found under Wireless > 802.11<a/b>> RRM > General
i typically just run reports on PI to look at utilization historical data.
-Scott
-Scott
