custom sig for WLC
matt.s
Where can I download custom signatures for the WLC 4402?
Matt
Scott Fella
You have to customize it yourself. You need to download it from the controller to your tftp, mopen the sig file with a text editor and make your changes. Once you are done, you can upload it back onto your wlc. You do this from the same section where you would upload new code or backup/restore the wlc configuration.
-Scott
