CWA does not work with vWLC
shabbarbabrawala
Beginner
Beginner
we are using vWLC ver 8.2 with 1832 ap's the ap associates properly using flex connect but CWA page is not displayed when guest user is trying to connect, we use ISE for guest user authentication, this is what we found out
>> CWA is not supported with 1800 APs in flexconnect mode regarding below document and bug:
CSCva75030: CWA support for AP-COS APs in FlexConnect local switching mode
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCva75030/?reffering_site=dumpcr
Feature Matrix for 802.11ac Wave 2 Access Points
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_feature_matrix_for_802_11ac_wave2_access_points.html#concept_E42836143B734E4E8EA8C9AEE8028DBA
To make it work the 1800 APs should be in “local” mode, and that is not supported with the vWLC, on vWLC only APs in flexconnect mode are supported.
is there a solution to this bug seems the vWLC is very buggy as we have been hitting multiple bugs
Rafael E
You are right CWA + FlexConnect local switching is not supported on  wave 2 AP(s) yet.
The BUG you mention is the BUG created to make it work. We are working on this.
You can make it work having that WLAN as centrally switch. The above is not related to vWLC but this is a current limitation in all platforms and wave 2 APs
Rafael - TAC
Saludos,
Rafael - TAC
Thanks please can you clarify this
1. When is the expected date to fix this
2. If we use a hardware WLC will it work in the current scenario
3. You can make it work having that WLAN as centrally switch:- can you elaborate on how this will work
Shabbar Babrawala
Technical Consultant
T: +255 222 111 028/22 | M: +255784656507 | Ext: 422
<http://www.computechlimited.com/>
7th Floor, Diamond Plaza, Plot No. 162/38, Mirambo/Samora Avenue, Dar es Salaam, Tanzania
Kenya| Tanzania| Uganda| Rwanda| Zambia
<https://www.facebook.com/ComputechLimited> <https://www.linkedin.com/company/computech-limited> <https://twitter.com/wearecomputech> <http://www.computechlimited.com/>
Disclaimer:- This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify us by writing or electronically. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
#53590
Hi Shabbar,
  1. There is no ETA for this yet.
  2. No, The limitation is for FlexConnect AP(s) in local switching, so any WLC is affected
  3. You need to centrally switch the WLAN to have CWA working
I would suggest for you to work with your account team so they can push on this. I already see 7 other CU looking for the same.  So, I think you have a case to have this move quicker.
Rafael
Saludos,
Rafael - TAC
