Default-gateways for dynamic interfaces on 2504 controller
Sandeep Verma
I am setting up wifi flexconnect solution and is a bit confused regarding what should be the default gateway for the dynamic interfaces which will be created.
Will it be the same as the one for management interface or the will it be the one for the clients.
controller ip  172.16.1.100/24
default-gateway  172.16.1.254
vlan 10
dynamic interface 192.168.1.10/24
default-gateway    ?????
vif for this vlan on switch 192.168.1.254
default-gateway for clients  192.168.1.254
Kindly suggest .
35 Replies 35
You don't have a radius server?
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Hi Scott,
I am having Cisco ACS as Radius server.
Client gets authenticated now but on ACS logs the protocol is PEAP and not EAP-TLS.
Also i want to know whether a certificate is required on WLC in case of local EAP only ???
If you want to use local EAP then you don't need certificate for (peap) but EAP fast you need it .
Check it here:
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/100590-ldap-eapfast-config.html
for EAP-TLS , you have to install certificates on client PC & use EAP-TLS as EAP methods when connecting to wireless. On ACS you need to configure a policy/rule when to use EAP-TLS.
If you are using WLC as Auth Server, then it is required to install cert on WLC. Below post explain EAP cert installation process of WLC.
http://mrncciew.com/2013/04/22/configuring-eap-tls-on-wlc/
Rasika
**** Pls rate all useful resposnes ****
Rasika Thanks...I've already followed the link from your blog. Very helpful.
Most of the things are now working as expected.
Need some reference material to understand authentication protocols, related to EAP, PEAP, EAP-TLS, MSCHAP., if you can help.
Also one more issue i am facing is i've added 4 RADIUS servers on WLC and for my WLAN security i have just selected 2 of them. However on logs i can see requests being forwarded to other 2 also. So is there any way to filter RADIUS servers for particular WLAN's only.
Thanks in advance.
