DHCP issues in WLC
vijay kumar
Level 2
Level 2
Hi all ,
We are using 5508 WLC with 7.4.100.0 version and AP's are 3600 .we have configured internal DHCP lease for the clients . We have one SSID with  802.1x auth WPA2/AES encryption .
The problem is some 35 of our laptop is not getting IP address  oftenly from WLC .Remainig clients are getting IP with no problem .Any bug on this?
TS.
Sandeep Choudhary
Hi ,
is dhcp proxy is enabled?
can u plz post the ouput of the client:
1 .debug client <mac address>
2. sh sysinfo
3. show dhcp leases
4. show dhcp detailed scope
Rasika Nayanajith
Hi Vijay,
You are running on the very first release of 7.4 code & that came with lots of bugs. So it is highly recommended to upgrade your WLC software to either 7.4.110.0(7.4MR1) or 7.4.111.x (7.4MR2 pre-release) available through TAC
https://supportforums.cisco.com/docs/DOC-37334
I am sure your issue will get fixed by one of this upgrade.
Also make sure your WLC FUS also get upgraded to 1.7.0.0 if it is not already in that version.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/fus_rn_1_7_0_0.html
Rasika
***** Pls rate all useful responses *****
Saravanan Lakshmanan
what's the subnet size, how many clients are trying to get an ip.
get below debug from wlc while connecting the client.
debug client
debug dhcp message enable
