DHCP Problems on new SSID
marioderosa2008
Hi all,
I have an SSID where clients cannot get DHCP addresses. I have captured the following debug and from what I can see the WLC recieves the DHCP address from the DHCP server and then attempts to forward that to the Station but the station does not get it.
Is my thinking correct? If so, what can cause the client not to recieve the DHCP offer packet from the WLC?
Mario
*DHCP Socket Task: Dec 15 15:57:33.034: ac:7b:a1:10:21:74 DHCP selected relay 1 - 192.168.254.254 (local address 192.168.254.253, gateway 192.168.254.254, VLAN 51, port 1)
*DHCP Socket Task: Dec 15 15:57:33.034: ac:7b:a1:10:21:74 DHCP transmitting DHCP DISCOVER (1)
*DHCP Socket Task: Dec 15 15:57:33.034: ac:7b:a1:10:21:74 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Dec 15 15:57:33.034: ac:7b:a1:10:21:74 DHCP   xid: 0xc7944f1b (3348385563), secs: 0, flags: 0
*DHCP Socket Task: Dec 15 15:57:33.034: ac:7b:a1:10:21:74 DHCP   chaddr: ac:7b:a1:10:21:74
*DHCP Socket Task: Dec 15 15:57:33.034: ac:7b:a1:10:21:74 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:33.034: ac:7b:a1:10:21:74 DHCP   siaddr: 0.0.0.0,  giaddr: 192.168.254.253
*DHCP Socket Task: Dec 15 15:57:33.034: ac:7b:a1:10:21:74 DHCP sending REQUEST to 192.168.254.254 (len 350, port 1, vlan 51)
*DHCP Socket Task: Dec 15 15:57:33.034: ac:7b:a1:10:21:74 DHCP selecting relay 2 - control block settings:
                        dhcpServer: 0.0.0.0, dhcpNetmask: 0.0.0.0,
                        dhcpGateway: 0.0.0.0, dhcpRelay: 192.168.254.253  VLAN: 51
*DHCP Socket Task: Dec 15 15:57:33.034: ac:7b:a1:10:21:74 DHCP selected relay 2 - NONE
*DHCP Socket Task: Dec 15 15:57:35.042: ac:7b:a1:10:21:74 DHCP received op BOOTREPLY (2) (len 295,vlan 51, port 1, encap 0xec00)
*DHCP Socket Task: Dec 15 15:57:35.042: ac:7b:a1:10:21:74 DHCP setting server from OFFER (server 192.168.254.254, yiaddr 192.168.254.184)
*DHCP Socket Task: Dec 15 15:57:35.042: ac:7b:a1:10:21:74 DHCP sending REPLY to STA (len 414, port 1, vlan 0)
*DHCP Socket Task: Dec 15 15:57:35.042: ac:7b:a1:10:21:74 DHCP transmitting DHCP OFFER (2)
*DHCP Socket Task: Dec 15 15:57:35.042: ac:7b:a1:10:21:74 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Dec 15 15:57:35.042: ac:7b:a1:10:21:74 DHCP   xid: 0xc7944f1b (3348385563), secs: 0, flags: 0
*DHCP Socket Task: Dec 15 15:57:35.042: ac:7b:a1:10:21:74 DHCP   chaddr: ac:7b:a1:10:21:74
*DHCP Socket Task: Dec 15 15:57:35.042: ac:7b:a1:10:21:74 DHCP   ciaddr: 0.0.0.0,  yiaddr: 192.168.254.184
*DHCP Socket Task: Dec 15 15:57:35.042: ac:7b:a1:10:21:74 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:35.042: ac:7b:a1:10:21:74 DHCP   server id: 192.0.2.1  rcvd server id: 192.168.254.254
*DHCP Socket Task: Dec 15 15:57:35.045: ac:7b:a1:10:21:74 DHCP received op BOOTREQUEST (1) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Dec 15 15:57:35.045: ac:7b:a1:10:21:74 DHCP selecting relay 1 - control block settings:
                        dhcpServer: 192.168.254.254, dhcpNetmask: 0.0.0.0,
*DHCP Socket Task: Dec 15 15:57:35.045: ac:7b:a1:10:21:74 DHCP selected relay 1 - 192.168.254.254 (local address 192.168.254.253, gateway 192.168.254.254, VLAN 51, port 1)
*DHCP Socket Task: Dec 15 15:57:35.045: ac:7b:a1:10:21:74 DHCP transmitting DHCP REQUEST (3)
*DHCP Socket Task: Dec 15 15:57:35.045: ac:7b:a1:10:21:74 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Dec 15 15:57:35.045: ac:7b:a1:10:21:74 DHCP   xid: 0xc7944f1b (3348385563), secs: 0, flags: 0
*DHCP Socket Task: Dec 15 15:57:35.045: ac:7b:a1:10:21:74 DHCP   chaddr: ac:7b:a1:10:21:74
*DHCP Socket Task: Dec 15 15:57:35.045: ac:7b:a1:10:21:74 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:35.045: ac:7b:a1:10:21:74 DHCP   siaddr: 0.0.0.0,  giaddr: 192.168.254.253
*DHCP Socket Task: Dec 15 15:57:35.045: ac:7b:a1:10:21:74 DHCP   requested ip: 192.168.254.184
*DHCP Socket Task: Dec 15 15:57:35.045: ac:7b:a1:10:21:74 DHCP   server id: 192.168.254.254  rcvd server id: 192.0.2.1
*DHCP Socket Task: Dec 15 15:57:35.045: ac:7b:a1:10:21:74 DHCP sending REQUEST to 192.168.254.254 (len 374, port 1, vlan 51)
*DHCP Socket Task: Dec 15 15:57:35.045: ac:7b:a1:10:21:74 DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Dec 15 15:57:35.045: ac:7b:a1:10:21:74 DHCP selected relay 2 - NONE
*DHCP Socket Task: Dec 15 15:57:35.050: ac:7b:a1:10:21:74 DHCP received op BOOTREPLY (2) (len 278,vlan 51, port 1, encap 0xec00)
*DHCP Socket Task: Dec 15 15:57:35.050: ac:7b:a1:10:21:74 DHCP sending REPLY to STA (len 414, port 1, vlan 0)
*DHCP Socket Task: Dec 15 15:57:35.050: ac:7b:a1:10:21:74 DHCP transmitting DHCP NAK (6)
*DHCP Socket Task: Dec 15 15:57:35.050: ac:7b:a1:10:21:74 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Dec 15 15:57:35.050: ac:7b:a1:10:21:74 DHCP   xid: 0xc7944f1b (3348385563), secs: 0, flags: 0
*DHCP Socket Task: Dec 15 15:57:35.050: ac:7b:a1:10:21:74 DHCP   chaddr: ac:7b:a1:10:21:74
*DHCP Socket Task: Dec 15 15:57:35.050: ac:7b:a1:10:21:74 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:35.050: ac:7b:a1:10:21:74 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:35.050: ac:7b:a1:10:21:74 DHCP   server id: 192.0.2.1  rcvd server id: 192.168.254.254
*DHCP Socket Task: Dec 15 15:57:35.056: ac:7b:a1:10:21:74 DHCP received op BOOTREQUEST (1) (len 308,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Dec 15 15:57:35.056: ac:7b:a1:10:21:74 DHCP selecting relay 1 - control block settings:
                        dhcpGateway: 0.0.0.0, dhcpRelay: 0.0.0.0  VLAN: 0
*DHCP Socket Task: Dec 15 15:57:35.056: ac:7b:a1:10:21:74 DHCP selected relay 1 - 192.168.254.254 (local address 192.168.254.253, gateway 192.168.254.254, VLAN 51, port 1)
*DHCP Socket Task: Dec 15 15:57:35.056: ac:7b:a1:10:21:74 DHCP transmitting DHCP DISCOVER (1)
*DHCP Socket Task: Dec 15 15:57:35.056: ac:7b:a1:10:21:74 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Dec 15 15:57:35.056: ac:7b:a1:10:21:74 DHCP   xid: 0xa0788169 (2692252009), secs: 0, flags: 0
*DHCP Socket Task: Dec 15 15:57:35.056: ac:7b:a1:10:21:74 DHCP   chaddr: ac:7b:a1:10:21:74
*DHCP Socket Task: Dec 15 15:57:35.056: ac:7b:a1:10:21:74 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:35.056: ac:7b:a1:10:21:74 DHCP   siaddr: 0.0.0.0,  giaddr: 192.168.254.253
*DHCP Socket Task: Dec 15 15:57:35.056: ac:7b:a1:10:21:74 DHCP sending REQUEST to 192.168.254.254 (len 350, port 1, vlan 51)
*DHCP Socket Task: Dec 15 15:57:35.056: ac:7b:a1:10:21:74 DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Dec 15 15:57:35.056: ac:7b:a1:10:21:74 DHCP selected relay 2 - NONE
fastpath       Configures the fastpath debug options.
flexconnect    Configures debug of flexconnect.
fmchs          Configures the FMCHS debug options.
ft             Configures the 802.11r debug options.
group          Configures debug of wlan apgroup.
iapp           Configures the IAPP debug options.
ipv6           Configures the IPV6 debug options
l2age          Configures debug of Layer 2 Ago Timeout Messages.
l2roam         Configures the L2 Roam debug options.
license        Configures Debugging of Licensing
location       Configures the Location debug options.
lwapp          This command has been deprecated. Please use debug capwap instead
mac            Configures MAC debugging
media-stream   Configures the media-stream debug options
memory         Configures debug of memory allocation/release.
mesh           Configures the Mesh debug options.
mobile-concierge Configures the Mobile Concierge debug options.
mobility       Configures the Mobility debug options.
nac            Configures debug of Network Access Control (NAC).
nmsp           Configures the NMSP debug options.
ntp            Configures debug of NTP.
packet         Configures packet debugging options.
pem            Configures the access policy manager debug options.
--More-- or (q)uit
pm             Configures debug of security policy manager module
profiling      Configures the Profiling debug options
rbcp           Configures the RBCP debug options
rf-profile     Configures debug of rf-profile
rfid           Configures the Rfid debug options.
service        Configures the debug options for different Services.
snmp           Configures the SNMP debug options.
spectrum       Configures the spectrum debug options.
transfer       Configures the transfer debug options.
voice-diag     Enable Diagnostics for Voice Clients.
wcp            Configures debug of WLAN Control Protocol (WCP).
web-auth       Configures debugs for web-auth client.
wips           Configures the WIPS debug options.
wps            Configures debug of WPS.
(Cisco Controller) >debug A*DHCP Socket Task: Dec 15 15:57:37.486: ac:7b:a1:10:21:74 DHCP received op BOOTREQUEST (1) (len 308,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Dec 15 15:57:37.486: ac:7b:a1:10:21:74 DHCP selecting relay 1 - control block settings:
*DHCP Socket Task: Dec 15 15:57:37.486: ac:7b:a1:10:21:74 DHCP selected relay 1 - 192.168.254.254 (local address 192.168.254.253, gateway 192.168.254.254, VLAN 51, port 1)
*DHCP Socket Task: Dec 15 15:57:37.486: ac:7b:a1:10:21:74 DHCP transmitting DHCP DISCOVER (1)
*DHCP Socket Task: Dec 15 15:57:37.486: ac:7b:a1:10:21:74 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Dec 15 15:57:37.486: ac:7b:a1:10:21:74 DHCP   xid: 0xa0788169 (2692252009), secs: 768, flags: 0
*DHCP Socket Task: Dec 15 15:57:37.486: ac:7b:a1:10:21:74 DHCP   chaddr: ac:7b:a1:10:21:74
*DHCP Socket Task: Dec 15 15:57:37.486: ac:7b:a1:10:21:74 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:37.486: ac:7b:a1:10:21:74 DHCP   siaddr: 0.0.0.0,  giaddr: 192.168.254.253
*DHCP Socket Task: Dec 15 15:57:37.486: ac:7b:a1:10:21:74 DHCP sending REQUEST to 192.168.254.254 (len 350, port 1, vlan 51)
*DHCP Socket Task: Dec 15 15:57:37.486: ac:7b:a1:10:21:74 DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Dec 15 15:57:37.486: ac:7b:a1:10:21:74 DHCP selected relay 2 - NONE
Incorrect usage.  Use the '?' or <TAB> key to list commands.
(Cisco Controller) >*DHCP Socket Task: Dec 15 15:57:40.021: ac:7b:a1:10:21:74 DHCP received op BOOTREPLY (2) (len 295,vlan 51, port 1, encap 0xec00)
*DHCP Socket Task: Dec 15 15:57:40.021: ac:7b:a1:10:21:74 DHCP setting server from OFFER (server 192.168.254.254, yiaddr 192.168.254.186)
*DHCP Socket Task: Dec 15 15:57:40.022: ac:7b:a1:10:21:74 DHCP sending REPLY to STA (len 414, port 1, vlan 0)
*DHCP Socket Task: Dec 15 15:57:40.022: ac:7b:a1:10:21:74 DHCP transmitting DHCP OFFER (2)
*DHCP Socket Task: Dec 15 15:57:40.022: ac:7b:a1:10:21:74 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Dec 15 15:57:40.022: ac:7b:a1:10:21:74 DHCP   xid: 0xa0788169 (2692252009), secs: 0, flags: 0
*DHCP Socket Task: Dec 15 15:57:40.022: ac:7b:a1:10:21:74 DHCP   chaddr: ac:7b:a1:10:21:74
*DHCP Socket Task: Dec 15 15:57:40.022: ac:7b:a1:10:21:74 DHCP   ciaddr: 0.0.0.0,  yiaddr: 192.168.254.186
*DHCP Socket Task: Dec 15 15:57:40.022: ac:7b:a1:10:21:74 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:40.022: ac:7b:a1:10:21:74 DHCP   server id: 192.0.2.1  rcvd server id: 192.168.254.254
*DHCP Socket Task: Dec 15 15:57:40.023: ac:7b:a1:10:21:74 DHCP received op BOOTREQUEST (1) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Dec 15 15:57:40.024: ac:7b:a1:10:21:74 DHCP selecting relay 1 - control block settings:
*DHCP Socket Task: Dec 15 15:57:40.024: ac:7b:a1:10:21:74 DHCP selected relay 1 - 192.168.254.254 (local address 192.168.254.253, gateway 192.168.254.254, VLAN 51, port 1)
*DHCP Socket Task: Dec 15 15:57:40.024: ac:7b:a1:10:21:74 DHCP transmitting DHCP REQUEST (3)
*DHCP Socket Task: Dec 15 15:57:40.024: ac:7b:a1:10:21:74 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Dec 15 15:57:40.024: ac:7b:a1:10:21:74 DHCP   xid: 0xa0788169 (2692252009), secs: 768, flags: 0
*DHCP Socket Task: Dec 15 15:57:40.024: ac:7b:a1:10:21:74 DHCP   chaddr: ac:7b:a1:10:21:74
*DHCP Socket Task: Dec 15 15:57:40.024: ac:7b:a1:10:21:74 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:40.024: ac:7b:a1:10:21:74 DHCP   siaddr: 0.0.0.0,  giaddr: 192.168.254.253
*DHCP Socket Task: Dec 15 15:57:40.024: ac:7b:a1:10:21:74 DHCP   requested ip: 192.168.254.186
*DHCP Socket Task: Dec 15 15:57:40.024: ac:7b:a1:10:21:74 DHCP   server id: 192.168.254.254  rcvd server id: 192.0.2.1
*DHCP Socket Task: Dec 15 15:57:40.024: ac:7b:a1:10:21:74 DHCP sending REQUEST to 192.168.254.254 (len 374, port 1, vlan 51)
*DHCP Socket Task: Dec 15 15:57:40.024: ac:7b:a1:10:21:74 DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Dec 15 15:57:40.024: ac:7b:a1:10:21:74 DHCP selected relay 2 - NONE
*DHCP Socket Task: Dec 15 15:57:40.040: ac:7b:a1:10:21:74 DHCP received op BOOTREPLY (2) (len 278,vlan 51, port 1, encap 0xec00)
*DHCP Socket Task: Dec 15 15:57:40.040: ac:7b:a1:10:21:74 DHCP sending REPLY to STA (len 414, port 1, vlan 0)
*DHCP Socket Task: Dec 15 15:57:40.040: ac:7b:a1:10:21:74 DHCP transmitting DHCP NAK (6)
*DHCP Socket Task: Dec 15 15:57:40.040: ac:7b:a1:10:21:74 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Dec 15 15:57:40.040: ac:7b:a1:10:21:74 DHCP   xid: 0xa0788169 (2692252009), secs: 0, flags: 0
*DHCP Socket Task: Dec 15 15:57:40.040: ac:7b:a1:10:21:74 DHCP   chaddr: ac:7b:a1:10:21:74
*DHCP Socket Task: Dec 15 15:57:40.040: ac:7b:a1:10:21:74 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:40.040: ac:7b:a1:10:21:74 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:40.040: ac:7b:a1:10:21:74 DHCP   server id: 192.0.2.1  rcvd server id: 192.168.254.254
*DHCP Socket Task: Dec 15 15:57:40.044: ac:7b:a1:10:21:74 DHCP received op BOOTREQUEST (1) (len 308,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Dec 15 15:57:40.044: ac:7b:a1:10:21:74 DHCP selecting relay 1 - control block settings:
*DHCP Socket Task: Dec 15 15:57:40.044: ac:7b:a1:10:21:74 DHCP selected relay 1 - 192.168.254.254 (local address 192.168.254.253, gateway 192.168.254.254, VLAN 51, port 1)
*DHCP Socket Task: Dec 15 15:57:40.044: ac:7b:a1:10:21:74 DHCP transmitting DHCP DISCOVER (1)
*DHCP Socket Task: Dec 15 15:57:40.044: ac:7b:a1:10:21:74 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Dec 15 15:57:40.044: ac:7b:a1:10:21:74 DHCP   xid: 0x99a9937f (2578027391), secs: 0, flags: 0
*DHCP Socket Task: Dec 15 15:57:40.044: ac:7b:a1:10:21:74 DHCP   chaddr: ac:7b:a1:10:21:74
*DHCP Socket Task: Dec 15 15:57:40.044: ac:7b:a1:10:21:74 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:40.044: ac:7b:a1:10:21:74 DHCP   siaddr: 0.0.0.0,  giaddr: 192.168.254.253
*DHCP Socket Task: Dec 15 15:57:40.045: ac:7b:a1:10:21:74 DHCP sending REQUEST to 192.168.254.254 (len 350, port 1, vlan 51)
*DHCP Socket Task: Dec 15 15:57:40.045: ac:7b:a1:10:21:74 DHCP selecting relay 2 - control block settings:
debug*DHCP Socket Task: Dec 15 15:57:40.045: ac:7b:a1:10:21:74 DHCP selected relay 2 - NONE
*DHCP Socket Task: Dec 15 15:57:42.058: ac:7b:a1:10:21:74 DHCP received op BOOTREPLY (2) (len 295,vlan 51, port 1, encap 0xec00)
*DHCP Socket Task: Dec 15 15:57:42.058: ac:7b:a1:10:21:74 DHCP setting server from OFFER (server 192.168.254.254, yiaddr 192.168.254.191)
*DHCP Socket Task: Dec 15 15:57:42.058: ac:7b:a1:10:21:74 DHCP sending REPLY to STA (len 414, port 1, vlan 0)
*DHCP Socket Task: Dec 15 15:57:42.058: ac:7b:a1:10:21:74 DHCP transmitting DHCP OFFER (2)
*DHCP Socket Task: Dec 15 15:57:42.058: ac:7b:a1:10:21:74 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Dec 15 15:57:42.058: ac:7b:a1:10:21:74 DHCP   xid: 0x99a9937f (2578027391), secs: 0, flags: 0
*DHCP Socket Task: Dec 15 15:57:42.058: ac:7b:a1:10:21:74 DHCP   chaddr: ac:7b:a1:10:21:74
*DHCP Socket Task: Dec 15 15:57:42.058: ac:7b:a1:10:21:74 DHCP   ciaddr: 0.0.0.0,  yiaddr: 192.168.254.191
*DHCP Socket Task: Dec 15 15:57:42.058: ac:7b:a1:10:21:74 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:42.058: ac:7b:a1:10:21:74 DHCP   server id: 192.0.2.1  rcvd server id: 192.168.254.254
*DHCP Socket Task: Dec 15 15:57:42.061: ac:7b:a1:10:21:74 DHCP received op BOOTREQUEST (1) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Dec 15 15:57:42.061: ac:7b:a1:10:21:74 DHCP selecting relay 1 - control block settings:
*DHCP Socket Task: Dec 15 15:57:42.061: ac:7b:a1:10:21:74 DHCP selected relay 1 - 192.168.254.254 (local address 192.168.254.253, gateway 192.168.254.254, VLAN 51, port 1)
*DHCP Socket Task: Dec 15 15:57:42.061: ac:7b:a1:10:21:74 DHCP transmitting DHCP REQUEST (3)
*DHCP Socket Task: Dec 15 15:57:42.061: ac:7b:a1:10:21:74 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Dec 15 15:57:42.061: ac:7b:a1:10:21:74 DHCP   xid: 0x99a9937f (2578027391), secs: 0, flags: 0
*DHCP Socket Task: Dec 15 15:57:42.061: ac:7b:a1:10:21:74 DHCP   chaddr: ac:7b:a1:10:21:74
*DHCP Socket Task: Dec 15 15:57:42.061: ac:7b:a1:10:21:74 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:42.061: ac:7b:a1:10:21:74 DHCP   siaddr: 0.0.0.0,  giaddr: 192.168.254.253
*DHCP Socket Task: Dec 15 15:57:42.061: ac:7b:a1:10:21:74 DHCP   requested ip: 192.168.254.191
*DHCP Socket Task: Dec 15 15:57:42.061: ac:7b:a1:10:21:74 DHCP   server id: 192.168.254.254  rcvd server id: 192.0.2.1
*DHCP Socket Task: Dec 15 15:57:42.062: ac:7b:a1:10:21:74 DHCP sending REQUEST to 192.168.254.254 (len 374, port 1, vlan 51)
*DHCP Socket Task: Dec 15 15:57:42.062: ac:7b:a1:10:21:74 DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Dec 15 15:57:42.062: ac:7b:a1:10:21:74 DHCP selected relay 2 - NONE
*DHCP Socket Task: Dec 15 15:57:42.069: ac:7b:a1:10:21:74 DHCP received op BOOTREPLY (2) (len 278,vlan 51, port 1, encap 0xec00)
*DHCP Socket Task: Dec 15 15:57:42.070: ac:7b:a1:10:21:74 DHCP sending REPLY to STA (len 414, port 1, vlan 0)
*DHCP Socket Task: Dec 15 15:57:42.070: ac:7b:a1:10:21:74 DHCP transmitting DHCP NAK (6)
*DHCP Socket Task: Dec 15 15:57:42.070: ac:7b:a1:10:21:74 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Dec 15 15:57:42.070: ac:7b:a1:10:21:74 DHCP   xid: 0x99a9937f (2578027391), secs: 0, flags: 0
*DHCP Socket Task: Dec 15 15:57:42.070: ac:7b:a1:10:21:74 DHCP   chaddr: ac:7b:a1:10:21:74
*DHCP Socket Task: Dec 15 15:57:42.070: ac:7b:a1:10:21:74 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:42.070: ac:7b:a1:10:21:74 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:42.070: ac:7b:a1:10:21:74 DHCP   server id: 192.0.2.1  rcvd server id: 192.168.254.254
*DHCP Socket Task: Dec 15 15:57:42.076: ac:7b:a1:10:21:74 DHCP received op BOOTREQUEST (1) (len 308,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Dec 15 15:57:42.076: ac:7b:a1:10:21:74 DHCP selecting relay 1 - control block settings:
*DHCP Socket Task: Dec 15 15:57:42.076: ac:7b:a1:10:21:74 DHCP selected relay 1 - 192.168.254.254 (local address 192.168.254.253, gateway 192.168.254.254, VLAN 51, port 1)
*DHCP Socket Task: Dec 15 15:57:42.076: ac:7b:a1:10:21:74 DHCP transmitting DHCP DISCOVER (1)
*DHCP Socket Task: Dec 15 15:57:42.076: ac:7b:a1:10:21:74 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Dec 15 15:57:42.076: ac:7b:a1:10:21:74 DHCP   xid: 0x35c06675 (901801589), secs: 0, flags: 0
*DHCP Socket Task: Dec 15 15:57:42.076: ac:7b:a1:10:21:74 DHCP   chaddr: ac:7b:a1:10:21:74
*DHCP Socket Task: Dec 15 15:57:42.076: ac:7b:a1:10:21:74 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Dec 15 15:57:42.076: ac:7b:a1:10:21:74 DHCP   siaddr: 0.0.0.0,  giaddr: 192.168.254.253
*DHCP Socket Task: Dec 15 15:57:42.076: ac:7b:a1:10:21:74 DHCP sending REQUEST to 192.168.254.254 (len 350, port 1, vlan 51)
*DHCP Socket Task: Dec 15 15:57:42.076: ac:7b:a1:10:21:74 DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Dec 15 15:57:42.076: ac:7b:a1:10:21:74 DHCP selected relay 2 - NONE
David Watkins
Level 4
Level 4
The client shows it is receiving the offer and sending a request back to the DHCP server.  The server is sending a NAK back to the client's request.
DISCOVER
OFFER
REQUEST
NAK!
The WLC is sending the traffic properly.  The DHCP server is sending back a NAK to the Client REQUEST.  It's a bit odd because the client is making a Request to the same DHCP server, with the same transaction ID, with the same "offered" IP address.  Once the DHCP Server sends back an "ACK" instead of a "NAK", then you will be good.
What is the device offering DHCP?  You might consider getting rid of DHCP-Proxy and simply bridging the traffic over.  Can you take a "wired" client and place them on VLAN 51 of that same switch and get an IP address?
Thanks for the reply.
it turned out that the broadband routing hosting the DHCP scope was the issue... not sure why it did not like the DHCP requests coming from the Wireless, but sure enough when i swapped it out with an old Cisco 877 with a basic DHCP scope, all works fine now.
thanks
Mario
Didn't like it probably because by default, the WLC has dhcp proxy enabled. There are various dhcp servers that will not respond to a proxy dhcp request and the fix is to disable that. Of course, replacing the dhcp with something that works fine with dhcp proxy will most likely work as in your case.
-Scott
-Scott
