ā07-08-2015 07:13 AM - edited ā07-05-2021 03:31 AM
I have 8 APs AIR-AP3702I and a controller WLC 2504. I want to have the same SSID, but I want that 4 of them to use 10.0.0.0/24 ip pool, and other 4 to use 10.0.2.0/24 pool.
Claudiu
Solved! Go to Solution.
ā07-08-2015 03:33 PM
Please refer to the below link :
https://supportforums.cisco.com/document/74486/ap-group-vlan-logic-wireless-lan-controllers-wlc-configuration-example
ā07-29-2015 09:46 AM
Here is the step by step GUI configuration guide of the AP group VLans with images.
https://www.cisco.com/public/technotes/smbsa/en/us/wireless/config_AP_Grp_VLANs_WLANs.pdf
for reference please look the below steps
ā07-08-2015 07:47 AM
You will want to look into the AP Groups feature.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-vlan/71477-ap-group-vlans-wlc.html
HTH,
Steve
ā07-10-2015 10:10 AM
You need "AP Group VLANs feature" in your 2504 Controller.
Check the following link for proper configuration step by step.
