difference between L3 & L2 protocols on WLC
john smith
what is the difference between layer3 or layer2 deployment in wireless lan controller?
how does layer3 works and configur ?
how does layer2 works and configur ?
any ideas about this?
Scott Fella
Here is a good link.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml
-Scott
Stephen Rodriguez
Piggy backing on Scott.
The L2 LWAPP means that all of your AP will be on the same subnet as the management/ap-manager interfaces.  In this mode the AP does not need an IP address, as it will broadcast to find the WLC.  This mode of operation is depricated and no longer chooseable, IIRC as of 5.0 code.
L3 LWAPP means that your AP can reside on any subnet so lon as they have IP reachability to the management/ap-manager interfaces.  All of the AP will have an IP address.
L3 is the most scalable, as you can spread the AP across your subnets, and do not have to rely on broadcasting for them to join.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
