i´m tryng to implement a wireless network using a AIR-WLC2125-K9 controller, and AIR-LAP1252AG-A-K9 access points, NOT using any ACS.
Somewhere i read that the WLC can authenticate a local database off users that are locally defined or in a LDAP (Active Directory) accessed by de WLC.
is this model able off locally authenticate?
the Access Control Server should be installed on the LADP Server as it is, when using ACS?
thanks
JLM
