02-11-2005 02:47 AM - edited 07-04-2021 10:26 AM
The Q&A document about Cisco SWAN says :
"Cisco Central Key Management to help ensure security of client roams"
Does it mean that only CCKM is supported ?
But what about WPA ? Is is supported for Fast Roaming and can I use it instead of CCKM ?
Are other protocols than CCKM supported ?
If you have documents about it, I am interested in.
Thank you,
Patrice
02-15-2005 05:03 PM
Answer: Yes
Answer: Only if you can convenice wi-fi
Answer: I think that there is a protocol proposed by IEEE. I forget the protocol name.
02-16-2005 12:02 AM
Hi dixho,
I thank you for your answers.
One last question : Could you explain more what you mean by :
Answer: Only if you can convenice wi-fi.
Thanks again,
Patrice
