Does the Cisco 2500 or 5500 have some sort of built in captive portal
holguie81
Does the Cisco 2500 or 5500 have some sort of built in captive portal.
If not can anyone provide a few suggestions?
Thanks in advanced
12 Replies 12
Scott Fella
Both have a portal for webauth if that what you are looking for. There is a default Cisco portal for passthrough, authentication or email address. You can also upload a custom HTML page if you wish.
Scott Fella
Sent from my iPhone
-Scott
I am looking to have web portal for guest access that collects basic user information
Well the wlc will not collect any additional information beside a username and or password. For specific information that needs to be entered an logged, you will need to use an external webserver and have the wlc redirect to that.
Scott Fella
Sent from my iPhone
-Scott
So the WLC can be set to redirect to specific web address or IP address. Does Cisco have a solution for captive portal? Or do you have any recommendations?
The WLC's has a built-in captive portal or you can your a custom HTML page you upload. The portal can either be a passthrough which the user just guys the accept, or a webauth in which they enter a username and password or an email entry.
Scott Fella
Sent from my iPhone
-Scott
Here is a link that might help
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008067489f.shtml
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008076f974.shtml
Scott Fella
Sent from my iPhone
-Scott
What do you mean by "collects basic user information"???
we would like to collect guest first name, last name and email address
You will need to use an external web server to capture that information.
Scott Fella
Sent from my iPhone
-Scott
Thanks. No suggestions for a third party captive portal?
david.g.white
You should take a look at Cisco NGS (Nac Guest Server)
This provides a portal where internal users can 'sponsor' guests on to the guest SSID, with certain logging options that can be tailored.
In addition to NGS, I'm fairly sure this is one of those core components of the BYOD functionality with the ISE.  There is a guest self registration system in ISE to my knowledge (as well as a sponsored guest option...?).
