02-01-2013 08:07 PM - edited 07-03-2021 11:28 PM
does wlc 2106 k9 support singapore based aps AIR AP 1131 AG-S-K9
Solved! Go to Solution.
02-01-2013 08:10 PM
Yes, as long as you choose Singapore in the configuration of the WLC.
02-01-2013 08:10 PM
02-01-2013 08:24 PM
Thank you Leo
it is mentioned as the location
02-02-2013 03:14 PM
Thanks for the ratings.
