DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
erictang03
flashfs[3]: 182 files, 7 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 31808000
flashfs[3]: Bytes used: 10418688
flashfs[3]: Bytes available: 21389312
flashfs[3]: flashfs fsck took 9 seconds.
flashfs[3]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 0 seconds.
flashfs[4]: Initialization complete....done Initializing flashfs.
Warning:  the compile-time code checksum does not appear to be present.
Radio0  present 8764B 8000 0 A8000000 A8010000 0
Rate table has 180 entries (48 SGI/72 BF variants)
Radio1  present 8764B 8000 0 88000000 88010000 4
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-SAP1602I-C-K9    (PowerPC) processor (revision B0) with 98294K/32768K
bytes of memory.
Processor board ID FGL1751S216
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: F0:7F:06:F0:87:EB
Part Number                          : 73-14671-04
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC1835322R
Top Assembly Part Number             : 800-38552-01
Top Assembly Serial Number           : FGL1751S216
Top Revision Number                  : A0
Product/Model Number                 : AIR-SAP1602I-C-K9
Press RETURN to get started!
*Mar  1 00:00:11.779: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-ta
ble No such file or directory
*Mar  1 00:00:11.867: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self t
est passed
*Mar  1 00:00:13.635: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
 test passed on interface Dot11Radio 0
*Mar  1 00:00:14.747: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
 test passed on interface Dot11Radio 1
*Mar  1 00:00:15.675: not a autoconfig enabled device!!!
*Mar  1 00:00:17.003: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state
to up
*Mar  1 00:00:18.003: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
ernet0, changed state to down
*Mar  1 00:01:03.863: Starting Ethernet promiscuous mode
*Mar  1 00:01:03.935: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to a
dministratively down
*Mar  1 00:01:03.935: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to a
*Mar  1 00:01:03.943: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1600 Software (AP1G2-K9W7-M), Version 15.2(2)JB, RELEASE SO
FTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport                                                  ;
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 11-Dec-12 04:30 by prod_rel_team
*Mar  1 00:01:03.943: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a c
old start
*Mar  1 00:01:04.931: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to up
*Mar  1 00:01:04.935: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
1, changed state to down
*Mar  1 00:01:15.903: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:01:16.903: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to down
ap>en
Password:
ap#ip http server
% Invalid input detected at '^' marker.
ap#
*Mar  1 00:03:09.090: %CDP_PD-4-POWER_OK: Full power - NON_CISCO-NO_CDP_RECEIVED
 inline power source
ap#
*Mar  1 00:04:21.481: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
ernet0, changed state to up
*Mar  1 00:04:23.481: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar  1 00:04:24.481: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to up
ap#
*Mar  1 00:06:55.779: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
*Mar  1 00:06:57.779: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:06:58.779: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to down
ap#conf t
Enter configuration commands, one per line.  E
ap(config)#hostname
% Incomplete command.
ap(config)#hostname
ap(config)#!
ap(config)#dot11 ssid
ap(config)#hostname Umy_Prod
Umy_Prod(config)#enable secret MySecretPassword
Umy_Prod(config)#no username Cisco
Umy_Prod(config)#username some_admin secret ssh_secret_password
Umy_Prod(config)#line console 0
Umy_Prod(config-line)#logging synchronous
Umy_Prod(config-line)#exec-timeout 180 0
Umy_Prod(config-line)#exit
Umy_Prod(config)#ip domain-name my.utacgroup.com
Umy_Prod(config)#cryto key generate rsa
Umy_Prod(config)#crypto key generate rsa
The name for the keys will be: Umy_Prod.my.utacgroup.com
Choose the size of the key modulus in the range of 360 to 4096 for your
  General Purpose Keys. Choosing a key modulus greater than 512 may take
  a few minutes.
How many bits in the modulus [512]: 2048
% Generating 2048 bit RSA keys, keys will be non-exportable...
[OK] (elapsed time was 7 seconds)
Umy_Prod(config)
*Mar  1 00:30:00.913: %SSH-5-ENABLED: SSH 1.99 has been enabled
Umy_Prod(config)#ip ssh version 2
Umy_Prod(config)#line vty 0 4
Umy_Prod(config-line)#transport input ssh
Umy_Prod(config)#dot11 ssid Umy_Prod
Umy_Prod(config-ssid)#authentication oen
Umy_Prod(config-ssid)#authentication open
Umy_Prod(config-ssid)#authentication key-management wpa version 2
Umy_Prod(config-ssid)#wpa-psk asci umyprd015
Umy_Prod(config-ssid)#guest mode
Umy_Prod(config-ssid)#guest-mode
Umy_Prod(config-ssid)#exit
Umy_Prod(config)#interface dot11Radio 0
Umy_Prod(config-if)#encyption mode ciphers aes-ccm
Umy_Prod(config-if)#encryption mode ciphers aes-ccm
Umy_Prod(config-if)#ssid Umy_Prod
Umy_Prod(config-if)#no shutdown
*Mar  1 00:38:13.584: %LINK-5-CHANGED: Interface Dot11Radio0
eset
*Mar  1 00:38:14.604: %DOT11-6-FREQ_SCAN: Interface Dot11Radio0, Scanning freque
ncies for 22 seconds
Umy_Prod(config-if)#exit
Umy_Prod(config)#exit
Umy_Prod#
*Mar  1 00:38:26.044: %SYS-5-CONFIG_I: Configured from console by console
Umy_Prod#copy
*Mar  1 00:38:38.748: %DOT11-6-FREQ_USED: Interface Dot11Radio0, frequency 2432
selected
*Mar  1 00:38:38.768: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:38:38.776: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state
wn
Umy_Prod#copy
*Mar  1 00:38:38.784: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
Umy_Prod#copy
*Mar  1 00:38:39.812: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:38:40.812: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
Umy_Prod#copy running0
*Mar  1 00:38:45.888: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar  1 00:38:46.888: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to up
Umy_Prod#copy running-config startup-config
Destination filename [startup-config]?
Building configuration...
[OK]
Umy_Prod#
*Mar  1 00:40:31.487: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
Umy_Prod#
*Mar  1 00:41:21.998: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cca2.2345
.87fe Associated KEY_MGMT[WPAv2 PSK]
Umy_Prod#
*Mar  1 00:41:52.790: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
 Station cca2.2345.87fe Reason: Sending station has left the BSS
*Mar  1 00:41:53.326: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cca2.2345
Umy_Prod#
*Mar  1 00:42:23.986: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
*Mar  1 00:42:24.662: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cca2.2345
Umy_Prod#
*Mar  1 00:42:31.246: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Umy_Prod#
*Mar  1 00:43:17.577: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cca2.2345
Umy_Prod#
*Mar  1 00:43:48.709: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
*Mar  1 00:43:49.357: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cca2.2345
Umy_Prod#
*Mar  1 00:44:20.057: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Umy_Prod#
*Mar  1 00:47:57.178: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cca2.2345
Umy_Prod#
*Mar  1 00:48:12.062: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Umy_Prod#
*Mar  1 00:51:04.525: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cca2.2345
Umy_Prod#
*Mar  1 00:51:35.676: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
*Mar  1 00:51:36.252: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cca2.2345
Umy_Prod#
*Mar  1 00:52:06.928: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
*Mar  1 00:52:07.548: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cca2.2345
Umy_Prod#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
*Mar  1 00:52:38.272: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
*Mar  1 00:52:38.884: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cca2.2345
Umy_Prod(config-ssid)#authentication key management
*Mar  1 00:53:09.615: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
*Mar  1 00:53:34.323: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to do
wn
*Mar  1 00:53:34.331: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar  1 00:53:35.323: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:53:35.359: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:53:36.359: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
Umy_Prod(config-ssid)#wpa-psk asci pa$$w0rd1
*Mar  1 00:53:59.559: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to do
wn
*Mar  1 00:53:59.567: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar  1 00:54:00.559: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:54:00.595: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:54:01.595: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:54:06.143: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to do
wn
*Mar  1 00:54:06.151: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar  1 00:54:07.143: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:54:07.179: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:54:08.179: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
Umy_Prod#
*Mar  1 00:54:16.207: %SYS-5-CONFIG_I: Configured from
Umy_Prod#
*Mar  1 00:54:30.303: %DOT11-7-AUTH_FAILED: Station cca2.2345.87fe Authenticatio
n failed
Umy_Prod#
*Mar  1 00:55:04.094: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cca2.2345
Umy_Prod#
*Mar  1 00:55:35.258: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
*Mar  1 00:55:35.818: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cca2.2345
Umy_Prod#copy
*Mar  1 00:56:06.514: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
*Mar  1 00:56:07.162: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cca2.2345
[OK]
Umy_Prod#
*Mar  1 00:56:37.897: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
*Mar  1 00:56:38.569: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cca2.2345
Umy_Prod#
*Mar  1 00:57:09.249: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Sandeep Choudhary
paste the complete config of the AP.
