nh6we
Beginner
Dropped clients and Load threshold violation
Can someone tell me if a load threshold violation can lead to dropped clients.  Is this error message just a notice or does the controller drop clients after reaching the threshold value.
Chris
5 REPLIES 5
it is my understand no. its just an alert that it is at or over the threshold ..
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
nh6we
Beginner
Thanks for the info.  Any ideas why I would be getting a load violation and having dropped clients?
The issue just started.  I did not have dropped clients in the past.
Can you do a show wlan for me and post the results.
Do you have load balance enabled ?
George,
   Did you get the image files I just sent?
Chris
Ravi Singh
Rising star
No it will not drop the connection because Threshold just triggers an alarm to notify the administrator that you configured limit of threshold is over.
Create
Recognize Your Peers
Content for Community-Ad
