dropping half-open TCP connection
giridar
Hi All,
 Our security team is recommending to configure the WLC to drop half-open TCP connections
I have 5520 with 8.5.151.0
I couldn't find much information on the internet
please advise
marce1000
              - I don't think that AireOS has any native support for that,
 M.
thank you, do we have to use any other managing tools
You also need to ask the Security team who performed this task, what is their recommendations to fix that - if you working on the networking side - you need to consider using FW - which can fixup and make security tighten for your network.
google how to perform security hardening cisco devices and learn the best practice, implement one at a time, and see if that fix the security audit.
https://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20180416-tsa18-106a
BB
thank you
