EAP and static WEP
mbaschieri
Community Member
does anyone knows if the 1200 series cisco access points support eap authentication with fixed wep keys? I've got a customer of mine with 500+ brand new field PCs, with no pcmcia nor pci slots and however no wireless hardware embedded. Now he wants to go wireless with the highest degree of security, but the only choice we have is to plug a wireless adapter out of the Ethernet interface. However no wireless adapter does support dynamic wep keys, so the customer says it should be enough security applying an eap method with static wep keys, but in our labs we wasn't able to make it working with a 1230 cisco ap and ios 12.3(2).
Tnx,
Massimo Baschieri
7 Replies 7
dsidley
Level 2
Level 2
Absolutely.
The following is from one of my 350 AP's...
The 802.11b int (D0) has it's encryption set to mandatory WEP with a static key in slot 1..
The first service set (ssid noeap) is for a couple of old legacy wlan adapters with no EAP support.
The second sevice set works for both EAP/PEAP and EAP/EAP-FAST.... authenticating through a RADIUS server.
It's just my personal opinion, but I would dump 12.3(2) and stay with 12.2(15)XR2
On the clients I use Funk's Odyssey clinet which allows me to setup login/network profiles.
I have the RADIUS re-keying every 30 minutes or so and am of the opinion that this would be a reasonably secure WLAN setup.
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit xxx transmit-key
encryption mode wep mandatory
ssid noeap
authentication open
accounting acct_methods
ssid eapPEAP eapEAP-FAST
authentication open eap eap_methods
authentication network-eap eap_methods
Hi David, tnx for your reply.
My setup is almost identical the yours except that I'm working on a 1230 with 12.3(2) and I'm using vlans, this is my setup
encryption key 1 size 128bit xxxx transmit-key
encryption vlan 1 mode wep mandatory
ssid tsunami
vlan 1
authentication open eap eap_rad
authentication network-eap eap_rad
And this is what receive from the ap:
Jan 24 08:54:59.622: %DOT11-7-AUTH_FAILED: Station 0000.8661.2192 Authentication
failed
Jan 24 08:55:04.964: AAA/BIND(0000000F): Bind i/f
I've tried to get rid of vlans without any luck.
Bye,
Max
Sounds like these are non-cisco cards.
Have you tried turning off Aironet extensions?
Issues with NON Cisco clients trying to associate
Aironet extensions are enabled by default to detect the capabilities of Cisco Aironet client devices for features such as load balancing, MIC, TKIP, Repeater Mode, World Mode and Limiting the power level on an associated device, see:
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_installation_and_configuration_guide_chapter09186a008014868c.html - 1038065
This can also affect the ability for NONE Cisco clients to associate with the AP
To turn off Aironet extensions:
interface dot11radio 0
no dot11 extension aironet
PD
Hi Patrick, tnx for your reply.
Yes, it's not a cisco card, more precisely is an ethernet-to-wireless adapter from axis, at the moment is the only one I have.
I've tried a cisco card but it doesn't allow me to configure a static wep key when I enable .1x auth.
Anyway aironet extensions are disabled.
Tnx again,
Max.
Would you happen to know of any free client software?
In fact I'm trying with WinXP EAP-PEAP and EAP-TLS native client, I'm waiting for an odyssey license, are you saying that will make the difference?
Tnx,
Max.
your encryption statements are incorrect...
In your example it appears that you are missing the vlan parameter for your encryption key slot 1...
encryption vlan 1 key 1 size 128bit, etc, etc
Either add the above to your RF interface or remove the
and replace with
They have to match.
Don't enable vlans unless you plan on using multiple ssid's
DaveFromPeg
