EAP-TLS help needed
srosenthal
Level 8
Level 8
I have a lab setup and I am trying to get EAP-TLS working.  I have ACS 4.2 running on my active directory machine which is also my certificate authority.  I obtained a cert for the ACS and installed it, reset the ACS, then edited the certificate trust list and restarted.
I added a user to the AD.  I then obtained a cert for my laptop logging into the certsrv as the user and installed it.
I added the user to the ACS.
When I try to connect from the wireless laptop using EAP-TLS with the wireless profile EAP TYPE set to Smart Card or Certificate the connection fails.  I have unchecked validate certficate authority with no luck connecting.
When I check the ACS under the failed attemps it says ACS user unknown.  This is the same user, all I did was change the EAP type on the laptop.
When I set the EAP type to PEAP I am able to get connected with or without validating the server certificate.
Any help would be greatly appreciated.
Seth
George Stefanick
I provided a few links that you may find helpful
TLS config example
http://www.cisco.com/en/US/customer/products/ps6366/products_configuration_example09186a00807917a6.shtml
TLS Video
http://www.youtube.com/watch?v=sazfGz2D3eo
I hope this helps. Please rate helpful post ... Thanks
