Embedded Wireless Controller and Standard WLC in the same network
Taiga2022
Hey guys,
I want to know whether I can deploy embedded wireless controller and 2504 controller in the same network?
The APs under each controllers will be operating in different SSID.
Will there be any problems from operation wise if we deployed it?
If there are problems, I would like to get a go around solution also.
Thank you.
Sincerely,
13 Replies 13
 I can see some problems but
 For example, the AP when boot up try resolve a specifc URL trying to get the wlc management IP address. On this case, both wlc coud respond to it.
 Another situation is when AP gets its IP address from dhcp server, you can also pass the wlc management IP address but which one you are going to send?
 You need to separate AP from one wlc in the same vlan and the other wlc in another vlan.
 If the wlc will propagate different ssids, at least here will be easier. In case you put the same   ssid, different problems will come.
The WLC is the 2504 which is already EOS.
I will be using Catalyst 9k Series for EWC and new APs.
As far as I checked, since 2504 is not compatible with new 9k series, I don't think the APs will initiate to 2504.
For the IP, I will be using static for APs and EWC as well.
But can create a mess in the network. They will send capwap request and will reveive capwap response. They try to join and realize that they cant. Then they will reboot and start over and over.
 Not simple solution. Yes, you can do it manually but at each weird problem you dont know the reaon, this situaon will pop up as a possible reason.
from my point of view
since each group of AP will join to specific WLC and use different SSID and there is no roaming then I don't see any issue.
image that you have two vendor work in same place is same case.
I see. I can propose the solution then.
Having old devices in the network makes harder for the design wise.
Thank you.
One more question,
Let's say If I use 2 Autonomous APs, is it possible for me to make them roam the same SSID?
If so, can I know the configuration advice?
JPavonM
@Taiga2022 for seamless roaming between autonomous APs, no they do not support OKC but is the client who remember the credentials and reauthenticate every time it moves between different autonomous APs.
You can check this post from @Nicolas Darchis (https://community.cisco.com/t5/wireless/pkc-or-okc/m-p/1587847#M183107)
if you are talking about old school IOS APs in autonomous mode (that's really not recent stuff anymore), I would forget about supporting fast roaming (i.e. not renegotiating keys when roaming), but regular roaming (With a reauthentication) will work just fine.
Your 2504/EWC setup can work but it's a source of trouble. When booting the EWC AP, it might be tempted to join the 2504. Even if it can't because the 2504 does not have the software image for it, the AP will still send many join request to it and that will delay that AP becoming the embedded controller. EWC was designed to NOT have any WLC in the subnet. To be honest, I would test it if I were you. You can for sure make it work, but you may encounter issue in case of power failure and all devices rebooting depending on boot order and things like that.
Is there any way to prevent the EWC AP to not send CAPWAP Request to the 2504?
to prevent it ? no
you could block it with an ACL on the port of the 2504 or the EWC port although.
For the ACL thing,
Could you provide example configuration on GUI or maybe CLI?
and do I also need to add ACLs on newer model APs as well?
no i can't. The ACL to be placed is to be placed onthe switchport of the switch where EWC or 2504 are connected. And blocking CAPWAP ports should be enough. A lot of it depends on your setup/subnets/type of devices you have.
friend How AP know the IP of WLC ?
we will config DHCP to send EWC IP or WLC IP according to AP Op43.
this make EWC AP know the IP of EWC only and send join to it only.
for other AP they will get IP of WLC and only send join to it .
If I am wrong please correct me.
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/97066-dhcp-option-43-00.html
If they're on the same vlan they will get the same option 43 from DHCP.
Remember AP behaviour, even when configured with static IP, they will often use DHCP discovery which can cause problems even if you configure static IPs.  They will also use broadcast discovery so will discover both old WLC and new EWC on the same vlan.  They will try to join all the WLC they discover.
The only 100% safe solution is to have them on separate vlans - the docs specifically say NOT SUPPORTED having them on the same vlan.
The solutions Nicholas suggested might help mitigate the problems you create by doing this but you're just making it more complicated and risking introducing other side effects and problems.  Keep it simple and keep them separate.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
