12-21-2018 10:10 AM - edited 07-05-2021 09:37 AM
Hi guys.
I'd like to enable 300 for n mode clients (they are not not ac compatible) at autonomous access point CAP3702e.
I applied followin configuration:
dot11 vlan-name a81m vlan 11
dot11 ssid a81m
vlan 11
authentication open eap EAP_METHODS
authentication network-eap EAP_METHODS
authentication key-management wpa version 2
mbssid guest-mode
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 11 mode ciphers aes-ccm
encryption mode ciphers aes-ccm
ssid a81m
antenna gain 0
stbc
mbssid
speed basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23.
channel least-congested 2437 2462
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.11
encapsulation dot1Q 11
no ip route-cache
no cdp enable
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid a81m
antenna gain 0
peakdetect
dfs band 3 block
stbc
mbssid
speed basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23. a1ss9 a2ss9 a3ss9
channel width 40-below
channel dfs
station-role root
no cdp enable
bridge-group 1
interface Dot11Radio1.11
no ip route-cache
no cdp enable
bridge-group 2
interface GigabitEthernet0
description -= .1q trunk to gate's gi6 - private VLAN 11 =-
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.11
description -= private wireless subnet 192.168.172.16/28 =-
no ip route-cache
bridge-group 2
no bridge-group 2 spanning-disabled
interface BVI1
description -= management subnet 192.168.172.0/28 =-
mac-address e865.1998.2fc4
ip address 192.168.172.11 255.255.255.240
no ip route-cache
interface BVI2
mac-address 0005.4938.23c6
no ip address
no ip route-cache
as results. whenever GN clients joined AP, successfully authenticated but getting just 150 mpbs.
I tried to setup "aXssXX" parameters for interface Dot11Radio0 but there is no options to do that.
Could you suggest?
p.s. interface bvi1 is AP management link.
Thank you.
12-21-2018 02:39 PM
The AP might support >300 Mbps but this will depend entirely if the wireless client(s) can support this speed or not.
12-21-2018 03:57 PM
