Enabling multicast on a WLC 2106
simonwynn
I'm rolling out a WLC based wifi solution to replace autonomous access points. System is currently in beta.
I've noticed that I cannot browse windows shares, nor connect to Bonjour enabled printers from Macs unless I enable some multicast and broadcast settings.
Currently I've enabled the global mulitcast and the forwarding broadcasts settings - this seems to fix things. Rather than just guessing are there any other settings I should select?
Simon
Stephen Rodriguez
Simon,
     You'd want to enable multicast > multicast and set a 239.x.x.x address, and enable IGMP snooping
You can also take a look at the following doc on this.
https://supportforums.cisco.com/docs/DOC-14713
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Ok, great, thx!
