08-28-2014 04:14 PM - edited 07-05-2021 01:27 AM
Hello Guys,
I´m in an environment where using WPA+WPA2 / AES I reach the same trhoughput without security, Aprox 12Mb. But, when TKIP is enabled, this throughput decrease to 5Mb. Is it normal or is a controller CPU processor intensive that decrease the throughput?
I tested web auth also and can reach 12Mb. Just with TKIP enabled this problem occur.
Tks.
Solved! Go to Solution.
08-28-2014 06:02 PM
Here are the rules for get high throughput or 802.11n data rates on your WLAN
1. WMM should be enabled (WLAN QoS tab -> WMM should be "allow" or "required")
2. Layer 2 security should be either WPA2/AES or Open (WLAN Security tab -> L2 Security)
Unless you comply with above, you won't get any 802.11n data rates(High Througput). As you said above, if you use TKIP then your throughput degradation is expected.
Rasika
**** Pls rate all useful responses *****
08-28-2014 06:02 PM
Rasika
