Error for the Cisco 5508 firmware 8.5.182.0 with Air-AP2802I-B-K9
kschin
Keep receiving the error of the AP unable to join issue, when it joins it will show the IP address with 0.0.0.0
DOT11_CFG[0] Radio Mode is changed from Local to Local
[*09/05/2024 04:52:13.8406] DOT11_CFG[1] Radio Mode is changed from Local to Local
[*09/05/2024 04:52:16.6110] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*09/05/2024 04:52:19.4618] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*09/05/2024 04:52:22.3127] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
11 Replies 11
Leo Laohoo
Scroll to the right and under Status.  Does it keep showing "Downloading"?
Thanks for your reply, not, it just shows remove options. According to the log, is the same firmware version as the WLC, because we inserted the bundle AP image to the WLC.
marce1000
  - The screenshot with the error includes : Regulatory domain check has failed for the AP
     Is the regulatory domain for the particular AP configured (and allowed) on the controller ?
 M.
Hi Marce,
At the moment we didn't set any settings about the regulatory domain for the particular AP, any where we can configure? if need to be enabled or allowed.
Thank you
  - It looks like this AP has a country code , not allowed on the controller ; intended or not =>
             Check manufacturing code for the AP , either on the packaging of the AP or on it's covers
             (or perhaps with the command show version on the AP)
   To adjust/add on  the controller : https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/country_codes.html#ID3428
  M.
Hi Marce,
Yes, for the country we set it to SG for the controller, and below attached is the AP version.
     >....Yes, for the country we set it to SG for the controller,
  - The country code SG is assigned for Singapore , yet the AP model ends on AIR-AP2802I-B-K9
     This corresponds to Puerto Rico , and USA
                        So that should be corrected ,
 M.
kschin
Hi Marce,
Tried setting the controller to the 3 countries, but the AP still had the same error.
Couldn't get the IP address, still 0.0.0.0
Thank you
kschin
Hi Marce,
After the 0.0.0.0 error under my AP log will show below.
Last AP Message Decryption Failure
Last AP Connection Failure
Timed out while waiting for ECHO repsonse from the AP
Last AP Disconnect Reason
Last Error Occurred
AP got or has been disconnected
Last Error Occurred Reason
Last Join Error Timestamp
Sep 06 02:14:05.026
Hi Marce,
Really appreciate your help, now i can see my AP in the wireless tab.
           - I can't see any specific issue from it ,
 M.
