EWC on 9120 - Performance issue - Upload speed
Martin Aslak
I have a 9120x that I have turned into an EWC to test the feature.
Running 17.2.1a (atm, to get an old 3802i ap to join later) (tested with 17.6.4 as well)
I have atm 2 SSID, 1 running on 2.4GHz for IOT devices and one with dual band. I have been tweaking the settings with Operational Rates for both band and configured all my tags / polices etc.
Now to the issue: Download speed is around 500Mbit (i can accept that) but my upload speed is about 1-2mbit. My WAN is 1000/1000 with the limit of the throughput of my ASA5506x so around 750.
additional info: AP is located next to me while testing. test with both a phone and a laptop.
I have read a lot of other threads and cisco config guide without any luck.
I hope you have some suggestions to what the issue can be or what to test???
Some output from my EWC:
EWC-AP#show wireless client mac-address ce1f.0763.66f6 detail | in Rate|Signal
Current Rate : 13.5
Supported Rates : 18.0,36.0,48.0,54.0
Radio Signal Strength Indicator : -38 dBm
Signal to Noise Ratio : 53 dB
EWC-AP#
EWC-AP#
EWC-AP#
EWC-AP#
EWC-AP#
EWC-AP#show wireless client mac-address DC41.a9bf.297b detail | in Rate|Signal
Current Rate : 13.5
Supported Rates : 6.0,18.0,36.0,48.0,54.0
Radio Signal Strength Indicator : -36 dBm
Signal to Noise Ratio : 60 dB
EWC-AP#
EWC-AP#
EWC-AP#
EWC-AP#
EWC-AP#
EWC-AP#
EWC-AP#
Client MAC Address : ce1f.0763.66f6
Client MAC Type : Locally Administered Address
Client IPv4 Address : 192.168.11.144
Client IPv6 Addresses : fe80::cc1f:7ff:fe63:66f6
Client Username: N/A
AP MAC Address : 1416.9dae.9260
AP Name: APA4B4-392A-6948
AP slot : 1
Client State : Associated
Policy Profile : MMA_NEW
Flex Profile : default-flex-profile
Wireless LAN Id: 3
WLAN Profile Name: Pretty Fly For A WiFi
Wireless LAN Network Name (SSID): Pretty Fly For A WiFi
BSSID : 1416.9dae.926e
Connected For : 147 seconds
Protocol : 802.11ax - 5 GHz
Channel : 52
Client IIF-ID : 0x90000006
Association Id : 1
Authentication Algorithm : Open System
Session Timeout : 1800 sec (Remaining time: 1654 sec)
Session Warning Time : Timer not running
Input Policy Name : None
Input Policy State : None
Input Policy Source : None
Output Policy Name : None
Output Policy State : None
Output Policy Source : None
WMM Support : Enabled
U-APSD Support : Enabled
U-APSD value : 0
APSD ACs : BK, BE, VI, VO
Fastlane Support : Disabled
Client Active State : Active
Power Save : OFF
Current Rate : 13.5
Mobility:
Move Count : 0
Mobility Role : Local
Mobility Roam Type : None
Mobility Complete Timestamp : 02/28/2023 20:30:07 CET
Client Join Time:
Join Time Of Client : 02/28/2023 20:30:07 CET
Client State Servers : None
Client ACLs : None
Policy Manager State: Run
Last Policy Manager State : IP Learn Complete
Client Entry Create Time : 147 seconds
Policy Type : WPA2
Encryption Cipher : CCMP (AES)
Authentication Key Management : PSK
AAA override passphrase : No
User Private Network : Disabled
User Private Network Drop Unicast : Disabled
Encrypted Traffic Analytics : No
Protected Management Frame - 802.11w : No
EAP Type : Not Applicable
VLAN Override after Webauth : No
VLAN : 11
Multicast VLAN : 0
WFD capable : No
Managed WFD capable : No
Cross Connection capable : No
Support Concurrent Operation : No
Central NAT : DISABLED
Session Manager:
Point of Attachment : capwap_90000004
IIF ID : 0x90000004
Authorized : TRUE
Session timeout : 1800
Common Session ID: 000000000000001C1C150156
Acct Session ID : 0x00000000
Auth Method Status List
Method : None
Local Policies:
Service Template : wlan_svc_MMA_NEW (priority 254)
VLAN : 11
Absolute-Timer : 1800
Server Policies:
Resultant Policies:
VLAN : 11
DNS Snooped IPv4 Addresses : None
DNS Snooped IPv6 Addresses : None
Client Capabilities
CF Pollable : Not implemented
CF Poll Request : Not implemented
Short Preamble : Not implemented
PBCC : Not implemented
Channel Agility : Not implemented
Listen Interval : 0
Fast BSS Transition Details :
Reassociation Timeout : 0
11v BSS Transition : Implemented
11v DMS Capable : No
QoS Map Capable : No
FlexConnect Data Switching : Local
FlexConnect Dhcp Status : Local
FlexConnect Authentication : Central
FlexConnect Central Association : No
Client Statistics:
Number of Bytes Received : 560201
Number of Bytes Sent : 236759
Number of Packets Received : 1593
Number of Packets Sent : 893
Number of Policy Errors : 0
Fabric status : Disabled
Radio Measurement Enabled Capabilities
Capabilities: Link Measurement, Neighbor Report, Passive Beacon Measurement, Active Beacon Measurement, Table Beacon Measurement, Statistics Measurement, AP Channel Report
Client Scan Report Time : Timer not running
Client Scan Reports
Assisted Roaming Neighbor List
Nearby AP Statistics:
EoGRE : No/Simple client
Device Type : Un-Classified Device (Phone)
Device Name : Unknown Device
Protocol Map : 0x000401 (OUI, DOT11)
Device OS : Android 13
Protocol : DOT11
Type : 0 12
Data : 0c
00000000 00 00 00 08 53 4d 2d 47 39 38 31 42 |....SM-G981B |
Type : 1 7
Data : 07
00000000 00 01 00 03 57 41 37 |....WA7 |
Type : 2 7
Data : 07
00000000 00 02 00 03 4e 45 45 |....NEE |
Type : 3 5
Data : 05
00000000 00 03 ff 01 31 |....1 |
Type : 4 14
Data : 0e
00000000 00 04 00 0a 41 6e 64 72 6f 69 64 20 31 33 |....Android 13 |
Type : 5 11
Data : 0b
00000000 00 05 00 07 55 6e 6b 6e 6f 77 6e |....Unknown |
Max Client Protocol Capability: Wi-Fi6 (802.11ax)
EWC-AP#
EWC-AP#
EWC-AP#
EWC-AP#
Client MAC Address : dc41.a9bf.297b
Client MAC Type : Universally Administered Address
Client IPv4 Address : 192.168.11.110
Client IPv6 Addresses : fe80::ae0b:403e:cc83:1c71
AP slot : 0
Wireless LAN Id: 2
WLAN Profile Name: IOT
Wireless LAN Network Name (SSID): IOT
BSSID : 1416.9dae.9260
Connected For : 154 seconds
Protocol : 802.11ax - 2.4 GHz
Channel : 11
Client IIF-ID : 0x90000005
Association Id : 2
Session Timeout : 1800 sec (Remaining time: 1646 sec)
U-APSD value : 0
Power Save : OFF
Current Rate : 13.5
Mobility:
Move Count : 0
Mobility Complete Timestamp : 02/28/2023 20:30:08 CET
Client Join Time:
Join Time Of Client : 02/28/2023 20:30:02 CET
Client ACLs : None
Client Entry Create Time : 154 seconds
Policy Type : WPA2
VLAN : 11
Multicast VLAN : 0
WFD capable : No
Session Manager:
IIF ID : 0x90000004
Authorized : TRUE
Common Session ID: 000000000000001B1C14EE34
Method : None
Local Policies:
VLAN : 11
Server Policies:
Resultant Policies:
VLAN : 11
Client Capabilities
Listen Interval : 0
QoS Map Capable : Yes
Client Statistics:
Number of Bytes Received : 644882
Number of Bytes Sent : 402628
Number of Packets Received : 2536
Number of Packets Sent : 1787
Signal to Noise Ratio : 59 dB
Capabilities: Neighbor Report, Passive Beacon Measurement, Active Beacon Measurement, Table Beacon Measurement
Client Scan Reports
APA4B4-392A-6948 (slot 0)
antenna 0: 7 s ago ........ -43 dBm
antenna 1: 7 s ago ........ -43 dBm
APA4B4-392A-6948 (slot 1)
antenna 0: 7 s ago ........ -38 dBm
antenna 1: 7 s ago ........ -38 dBm
Protocol Map : 0x000021 (OUI, HTTP)
EWC-AP#
Scott Fella
One of the best ways to troubleshoot throughput is to use iPerf or setup OpenSpeedTest-Server. What you want to do is test within your local lan. This will help you to understand where the issues might be. As an example, if using iPerf or OpenSpeedTest-Server and you see good upload and downloads, that eliminates the wireless and you can focus elsewhere on your network.
-Scott
Scott Fella
-Scott
Rich R
Have you checked your config with https://cway.cisco.com/wireless-config-analyzer/ using the output of "show tech wireless"?
I have a 9120 running 17.9.2 EWC and get very similar up and download speeds without any problems.  Didn't see any throughput problems with earlier versions either. I personally wouldn't recommend using 17.2.1 though!  3802 should still work fine on later releases.
