Existing 1811W, need to turn on wireless
thomasdzubin
I have an existing Cisco 1811W router, running just fine, but now I need to turn on wireless. All of the web docs that I see seem to involve turning on bridging? shouldn't it be sufficient just to put the Dot11Radio0 and Dot11Radio1 interfaces into the existing Vlan1 that the FastEthernet ports are already in or am I missing something obvious?
Does anyone have any good pointers to example wireless configs that I can use for templates for the 1811W router?
if you do not turn on bridging, then the wireless must have a diferent segment
example:
ethernet 192.168.10.10
wireless 192.168.20.10
and if you turn bridging on that way you can put in the same vlan and same segment
