03-27-2019 08:50 AM - edited 07-05-2021 10:08 AM
I am currently running Prime 2.1. I am about to deploy a new appliance with Prime 3.5. I wont be migrating all the data but will just add the WLCs to the new Prime.
Can I export the Maps from Prime 2.1 and import into Prime 3.5?
Thanks in advance.
03-27-2019 02:23 PM
Yes you can.
Two options:
Export the maps and then import them
Backup DB of old PI and import it to new PI.
03-27-2019 02:57 PM
03-27-2019 02:58 PM
Agree the DB restore is not the best option for a smooth upgrade
