Fat AP roaming
ulambaday
Beginner
Beginner
Hi all,
I am very new to wireless and I have question regarding the autonomous access point
Can we have Roaming with autonomous access points?? IF yes, what are the AP model that supports roaming
Any help is much appreciated!!!
1 REPLY 1
Scott Fella
Hall of Fame Guru Hall of Fame Guru
Hall of Fame Guru
They all support roaming. As long as the subnet for the client doesn't change. If your doing 802.1x and require fast roaming, you can do that also with the use of WDS.
http://www.cisco.com/en/US/docs/wireless/access_point/12.2_15_JA/configuration/guide/s15roamg.html
-Scott
