Field Notice for 2504 -- Power Supply ?
BRIAN SEKLECKI
        I dont see any current field notices for the 2500 Series WLAN Controller.
http://www.cisco.com/en/US/support/tsd_products_field_notice_summary.html
  However, my supplier (MJ Systems) is telling me that they've started processing 5+ RMAs based on faulty power supplies in
AIR-WLC2504-K9*
Has anyone else seen a prorlblem with WLC2504 and faulty DC Power Supply cable?
Video of the DC power supply instability:
https://plus.google.com/104636252182283970301/posts/6Ch2iFaRKKA
Thanks, ~BAS
Leo Laohoo
If you want a definitive answer, raise a Cisco TAC Case.
Sent from Cisco Technical Support Nintendo App
George Stefanick
I have a few 2500s in the field with no issues ..
Scott Fella
Mine still works! Had mine running since the 2504's came out.
-Scott
Freerk Terpstra
Level 7
Level 7
I haven't seen this issue with this unit (yet) either..
